touge_ae101 wrote:just don't drive it on any remotely soft grass.![]()
eskimo wrote:touge_ae101 wrote:just don't drive it on any remotely soft grass.![]()
haha, yea ive had a modded 4wd with mt's befor so know what a mess they can make of lawns
matt dunn wrote:Would definatly not buy any surf or Hilux with any version of the L series engines, turbo or not.
That looks to be the 1KZTE version which are alright.
fangsport wrote:matt dunn wrote:Would definatly not buy any surf or Hilux with any version of the L series engines, turbo or not.
curious to hear your logic behind this comment??
in what way?? define weak, pleasesergei wrote: L series without turbo are very weak.
due to insufficient cooling maintenence, and too small exhaust secondry, but any other engine will do the same thingsergei wrote:With turbo they are slightly better, but have major cooling issues that leads to head cracking.
sergei wrote:1KZTE also crack heads (due to non-maintenance of the cooling system) but at lot lesser rate. 1KZTE also goes very well.
fangsport wrote:PS, would have a 5L over either engine
fangsport wrote:in what way?? define weak, pleasesergei wrote: L series without turbo are very weak.due to insufficient cooling maintenence, and too small exhaust secondry, but any other engine will do the same thingsergei wrote:With turbo they are slightly better, but have major cooling issues that leads to head cracking.sergei wrote:1KZTE also crack heads (due to non-maintenance of the cooling system) but at lot lesser rate. 1KZTE also goes very well.
as above, when fitted to a surf/prado (predominantly auto), both engines have a bad reputation for overheating and head-cracking, but when either is fitted to a manual vehicle, there dosn't seen to be such an issue.
a lot of people expect to be able to tow heavy trailers/caravans/boats, with these vehicles, with auto.............without a decent trans cooler, then wonder why it is overheating?????
matt dunn wrote:fangsport wrote:PS, would have a 5L over either engine
We had a reasonable late model NZ new Hilux with the 3.0L 5L diesil motor.
Used a tank of gas each way to chch for a race weekend and struggled to get to 100K on the flat.
Enough to put me off them for life.
Hell even the Campervan can beat that for speed and gas mileage.
The 5L may be a bit more reliable than the other L series stuff,
but is so down on power it's just not woth it.
Need a week to get anywhere.
touge_ae101 wrote:eskimo wrote:touge_ae101 wrote:just don't drive it on any remotely soft grass.![]()
obviously wasn't at MM10??
eskimo wrote:touge_ae101 wrote:eskimo wrote:touge_ae101 wrote:just don't drive it on any remotely soft grass.![]()
No
Users browsing this forum: No registered users and 29 guests
