Where to get Roll cage tube from..?
Postby trd-drifting » Wed Jan 19, 2011 5:19 pm
Can you buy roll cage tube other than places like cardwells and, race workshops etc just wondering..
Got quoted for chromolly $800 for only 18m worth from a local shop, i thought that wasa bit expensive.
Any where to getlike mild steel 44.5mm by 2.5 and 38mm tube as that what the specs say.
I live near hamilton
trd-drifting
Postby Adoom » Wed Jan 19, 2011 5:28 pm
I think you can get it the mild steel stuff from Steel & Tube. You probably have to buy full lengths, I don't think they will sell you part lengths.
Just make sure its the right stuff. Cold drawn seamless etc etc...
Adoom
Postby LEAKER » Wed Jan 19, 2011 5:50 pm
Yeah steel and tube would be your best bet and it's possible Chase auto components MAY be able to get it. They're an exhaust shop but i would imagine they would have access to various types of automotive tube.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby evil_si » Wed Jan 19, 2011 8:24 pm
advanced four wheel equipment in auckland sell chromolly tube
http://www.afwe.co.nz/
evil_si
Postby touge_ae101 » Wed Jan 19, 2011 9:22 pm
the 44mm main hoop tubing you can only get from vulcan steel. there other 44mm tubes you can get but the specs don't line up to what MSNZ want for the cages. its hella expensive as well.
chromoly is always going to be expensive if you go down that route you just have to grin and bear it.
touge_ae101
Postby matt dunn » Wed Jan 19, 2011 10:42 pm
remembering that as of the start of this year the spec required for MSNZ changed.
Postby strx7 » Wed Jan 19, 2011 11:00 pm
unless you really know what you are doing in regards to the welding of it, I wouldn't touch Chrome Moly.
Postby trd-drifting » Thu Jan 20, 2011 9:19 am
Quite happly weld either the steels its part of my job so no worrys there. I just want to get a price comparison of them Both. I will ring the companys you have spoke of.
Yeah as of this year the main hoop has to be 44.5 by 2.5 in mild and the rest can be 38.1 by 2.5. Ive read all the regs etc..
Cheers for all the responces
trd-drifting
Postby strx7 » Thu Jan 20, 2011 12:01 pm
they reckon the weight difference of a full cage in MS vs a full cage in CM is only 7-8kg. the price difference makes for expensive weight loss.
probably cheaper to go to jenny craig and shed 8kg off ya own body (if thats possible)
Postby trd-drifting » Thu Jan 20, 2011 1:45 pm
Haha yeah maybe i should try that but then there might not be anything left. Worth a shot :) Priced up steel and tube they got prices and reasonable, about 100 per length. Mild steel it is. Hope this is not going to be a f*** up :P
trd-drifting
Postby strx7 » Thu Jan 20, 2011 3:53 pm
that'd be right, a few years ago when i built my cage i think i paid $55 a length and that was a fairly mates rates type deal
Postby Boost_4_Life » Fri Jan 21, 2011 8:55 am
would it be easier to get one of our 'yocal cage builders to do the whole job then you know its right, or are you on a tight budget?
The rally beast
The rally beast again!
Boost_4_Life
Postby strx7 » Fri Jan 21, 2011 11:07 am
labour at $50 an hour soon makes for a $2000+ rollcage
Postby Boost_4_Life » Fri Jan 21, 2011 11:17 am
mmm, local guru is between 1500-1800incl depending on bars and the car obviously. spose if u can weld why not have a go. just watch the angles and as said new reg regarding main hoop size.
The rally beast
Boost_4_Life
Postby Bazda » Fri Jan 21, 2011 11:40 am
Remember you cant just buy any mild steel.
It has to be the MSNZ approved one.
Postby touge_ae101 » Fri Jan 21, 2011 12:53 pm
most of the hassle of doing it yourself is getting a bender that is suitable also and being able to fill out the MSNZ paperwork regarding how you built it.
just got mine done and yeah its guna cost at least $2000+ for a simple cage. most of it is the materials they are almost half the cost. but TBH i would rather be without $2000 and be safe if i had a big crash then have the extra $2000 cash in my pocket. :o
touge_ae101
Postby strx7 » Fri Jan 21, 2011 1:30 pm
if you trust your construction of the cage with your life, why not?
Postby trd-drifting » Fri Jan 21, 2011 1:38 pm
Yeath thats been the big problem and wasnt sure where to get before this but found out now vulcan and steel and tube have the approved MSNZ stuff that comes with the paper work both companys retail at around $140-$150 per length after i started this. We deal with steel and tube so can get it about $85-$100+gst depending size.
Mitchell motor sport for a 6 point are about $2700+GST just for a 6 point. Got all the paper work printed off to get it homlogated and getting a bit of a hand from a guy from work that built 3 or so cages before, think im ready to do it now, read all regs and asked questons to the guys at MSNZ
Thanks for all the responces helped me heaps and saved me some money :)
trd-drifting
Postby Dunny » Fri Jan 21, 2011 1:59 pm
Hey Guys,
Just to add to this thread for those that can weld a cage in themselves.
Dave McCahon down here does 'cage kits' for most cars. He has specs from many many cars and can supply a full pre bent kit within a few days normally.
I haven't heard if he is still in business doing that, but have used him for 3+ cages in the past and have all been really good, come pre bent, with any additional bars, footing plates + all the MSNZ spec's for paperwork, and reasonably priced. He is/was a MSNZ inspector so knows what is required.
That then saves all the hassle of measuring and bending
davemac@paradise.net.nz
SMS Motorsport
027 4341541
'81 KP61 uprighted 4k racecar (built by Rush Automotive)
'72 KP30 2 door
Dunny
Postby fangsport » Sat Jan 22, 2011 5:08 pm
Dunny wrote:Hey Guys,
SMS Motorsport
027 4341541
+1 for Dave, have installed a few of his cages, and a very good value for money (especially knowing his bends are legal).
just get the basic 6 point kit off him and add any extra straight braces/ diagonals etc to suit
fangsport
