Where to flow test injectors?
Postby Adoom » Thu Dec 29, 2011 11:47 am
Can anyone recommend where to get injectors tested/cleaned in Wellington/Hutt?
Diesel and Turbo said $40-45 per injector.
Adoom
Postby Shrike » Thu Dec 29, 2011 1:06 pm
I think shred and stm can do it from memory
Why dream it when you can live it
Shrike
Postby Bling » Thu Dec 29, 2011 1:09 pm
Not in welly, but i'm pretty sure Matt Dunn can do it
Postby Adoom » Thu Dec 29, 2011 1:55 pm
Shrike wrote:I think shred and stm can do it from memory
I don't think Shred do. They are the ones who said I should test any injectors I get, otherwise I would just waste money on my tune if the injectors are bung. They didn't imply that they could test them...
stm don't say anything on their website about injector testing.
Adoom
Postby Mr Revhead » Thu Dec 29, 2011 2:13 pm
Lots of places can do it. Most Auto Sparkys I'd imagine.
Alexanders in Welly do for sure.
But seeing as you well up in Boganville I'd ring a few local sparkys
Postby iOnic » Thu Dec 29, 2011 2:21 pm
Dont think you're gonna get much cheaper than Diesel and Turbo. There was a fuel injection place on Sydenham St that I had mine done. Dunno if they're still there. Cost me more than you've been quoted and for all I know they probably went to D&T to get done :lol:
Postby Grrrrrrr! » Thu Dec 29, 2011 3:52 pm
+1 to what ionic said, that seems to be the going rate, tho I have been quoted $130 each for side feeds + replacing all the seals etc.
Grrrrrrr!
Postby Adoom » Thu Dec 29, 2011 4:44 pm
I will go for D&T, I just wanted to see if there were any other options.
Hopefully my injectors arrive tomorrow :D
Adoom
Postby mjrstar » Thu Dec 29, 2011 6:16 pm
I once took a set of vr4 injectors to petroject in and they told me that it was pretty much a waste of time to get them flow tested and to only worry about flow testing if there was issues after fitting them.
Since then I have brought and used about 6 sets of second hand injectors and never bothered getting them tested before getting the car tuned...
I am not saying that this is necessarily a good practice but it seems to have worked for me so far...
current cars:
Evo 4 230Kw atw
1971 mini.
79 bugeye 245kw atw.
mjrstar
Postby matt dunn » Thu Dec 29, 2011 6:24 pm
BZG|Bling wrote:Not in welly, but i'm pretty sure Matt Dunn can do it
yeah Ican do them, and for about 1/2 that price.
Postby AE82 FXGT » Thu Dec 29, 2011 6:33 pm
I imagine you are talking about petrol injectors?
Ask around local garages, they would know a local place to get them done.
I took mine to a local place and I watched as the guy (used to work at my work place before I started but was on good terms with) ultrasonically cleaned the injectors and then flow tested them and then replaced the seals all for free.
There isn't that much (labour wise) to flow testing them, more so the equipment and jigs they have set up.
AE82 FXGT
Postby Adoom » Thu Dec 29, 2011 7:26 pm
mjrstar wrote:I once took a set of vr4 injectors to petroject in and they told me that it was pretty much a waste of time to get them flow tested and to only worry about flow testing if there was issues after fitting them.
It is tempting. But dyno time is more expensive than testing injectors. :?
Adoom
Postby d1 mule » Thu Dec 29, 2011 7:39 pm
Adoom wrote:It is tempting. But dyno time is more expensive than testing injectors. :?
not at the rate you quoted in your first post....
i got 4 tested with all new seals from vantage in chch for $50
d1 mule
Postby Adoom » Thu Dec 29, 2011 7:45 pm
Cool, I will keep it in mind.
Adoom
Postby steroidcontaskie » Mon Jan 16, 2012 3:22 pm
I would advise against that. I have recerntly flow tested 11 rx7 injectors (from 3 different cars) and only 6 flowed the same. With in the each set had at least one the was flowing so low as to be a real issue when it comes to tunning. Is saving on flow testing worth risking running lean?
Science never sleeps...
RVR Turbo (idle)
steroidcontaskie
