ST183 Celica Steering Column
Postby MAC_HATER » Thu Feb 23, 2012 10:17 pm
Hey everyone,
Celica has failed a warrant on "Steering Column slack"
the column is bolted on nice and tight and doesnt move - but it is an adjustable tilt\length one - and you can jiggle the steering wheel up and down about a cm in each direction
apart from this you can extend or retract the length of the column, but you cant adjust it up or down - ive had a bit of a tinker but its all tight - im suspecting the column itself is damaged? as its never worked properly - would that be a fair guess?
if thats the case it would probably be better to get a second hand replacment and swap them over? are there any differences between the models of celica?
Cheers :)
Aaron
~SlideWays~: Cars + Males = Single, therefore: Poptarts?
MAC_HATER
Postby LEAKER » Fri Feb 24, 2012 6:22 am
From memory it will have bearings internally which are poked. Just go down to pick a part and grab one, atleast that way you will have practise in pulling it off aswell.
The GT4 is to Celicas what the GTR is to skylines.
LEAKER
Postby MAC_HATER » Fri Feb 24, 2012 10:23 am
havent got a pick a part down here - just yards that want $450 for a single tail light :P
but awesome Cheers for that - if thats what it is i can at least start in the right direction - Cheers :D
MAC_HATER
Postby loudstealthGT-Four » Fri Feb 24, 2012 5:54 pm
You're more than welcome to rape the ST183 celica I have at my parents for wanted parts. :D
loudstealthGT-Four
