Need someone in Hamilton to help a bro out :)
Postby jondee86 » Wed Jul 11, 2012 10:40 pm
As said, is there any 4age guru in Hamilton who could spare a bit
of time to help a 4AGE noobie get his engine running ? Sounds
like it has a timing problem and maybe some electrical niggles. The
usual starts, gives one rev and dies... but sometimes can struggle
on for a few more seconds... dies if you try to open the throttle kind
of thing.
Nothing in for ya except the warm glow of satisfaction from helping
a 4AGE bro get his car working :)
PM me or post a contact number here, and I'll put you in touch.
Cheers... jondee86
Watch this space >>> <<<
jondee86
Postby headshotnz » Wed Jul 11, 2012 11:28 pm
Check the knock sensor on the back under the intake manifold is plugged in, or working.
Current: UCF20 NZ New LS400,
(Current project) Gen II SW20 Turbo (MR2 v0.5Beta currently in the works)
Previous: Ae101 trueno (S/S), ST185 Group A, Accord with adjustables and H22a certed. SW20 (ct20b, blitz ecu) Uzz30, ae101 s/s 20v c56(-04c;) ) lsd, ae100 beast 5afe(for maximum horsepowers)
headshotnz
Postby l1ttle_d3vil » Wed Jul 11, 2012 11:57 pm
Might be in Hamilton weekend of 21st, but not sure what spare time / transport I'll have though.
What model 4age?
Probably something like faulty TPS, bung ECU or like you say the timing.
Postby jondee86 » Thu Jul 12, 2012 12:41 pm
This here is his tale of woe....
http://forums.club4ag.com/zerothread?id=108994
Seems the engine is not far off running, but one or more small problems
are getting in the way. Just needs a logical approach to eliminating each
possible cause, until you find the issue. As said, I'm guessing timing, but
ther could be something else involved. Engine is TVIS 16V 4AGE into a
KP... with a bit of mix n match on the loom.
If you want I can PM you his email so you can touch base.
Cheers... jondee86
jondee86
Postby jondee86 » Fri Jul 13, 2012 1:54 pm
Anyone with a spare hour to take a look ?? Definitely be beers in it if
you can get it sorted :)
Cheers... jondee86
jondee86
Postby 85AW20v » Fri Jul 13, 2012 5:52 pm
I'd be looking at the engine start relay not keeping the fuel pump running after the engine has started. Bridge it in the diagnostic box and see how it goes then.
See ya
Simon
85 MR2 20v
85AW20v
