Mag Wheel Warranty Query?
Postby Garreth27 » Thu Oct 04, 2012 11:31 pm
I bought some 19's on October 15 last year brand new direct from a mag shop but I have now discovered that the inside of the rim and around on some of the spokes they are starting to flake and peel. I take it that this shouldn't happen to wheels that are not even that old.
Would this be covered under warranty as i assume it comes with the standard 12 month warranty and i am still within that period provided i can find trhe damn receipt
Current Rides:
91 Gt Starlet - Forged 5efte Drag Toy
88 EP71 Turbo S Starlet Track Toy
99 SEX10 Altezza - Daily Driver
Garreth27
Postby Grrrrrrr! » Thu Oct 04, 2012 11:46 pm
Dont worry about what they say the warranty is or isn't.. go CGA on their arse if they dont offer to fix/replace.
Grrrrrrr!
Postby Leon » Fri Oct 05, 2012 7:43 am
Yup, I'd say you should be able to get them repaired or replaced easily enough if the trader is still around. You'd be reasonable to expect that a wheel wouldn't start looking tatty in a year through no fault of your own.
Postby Mr Ree » Fri Oct 05, 2012 8:16 am
Just make sure to not talk about how you use brake pads with corosive pad compound, or how you use a caustic mag wheel cleaner on them etc.
If they have flaked simply from being on the car, the the CGA has you covered.
Products must be fit for purpose, and last a reasonable amount of time being used as would be expected
wak thud gush!
Mr Ree
Postby Garreth27 » Fri Oct 05, 2012 2:36 pm
Spoke to the head office of mag and tyre direct and they will be giving a copy of the receipt. Car was hardly used with the mags and I always kept them clean, I usually just used soapy water to clean them, and then rinsed them and wiped them down with a towel, only used a sponge to clean them. Car has done prob 200km in the last 6months so it's barely been driven on to get much brake dust. Hopefully they will be good abt it. Next time think ill just go to platinum wheels for some rims.
Current Rides:
Garreth27
Postby tsoob » Fri Oct 05, 2012 6:35 pm
buy it cheap buy it twice.
Platinum Wheels
15 Parkway Drive
Mairangi Bay
09 486 5317
WHEELS, TYRES & SUSPENSION!
www.platinumwheels.co.nz
tsoob
Postby Garreth27 » Fri Oct 05, 2012 10:17 pm
yep 100% correct there.
Current Rides:
Garreth27
Users browsing this forum: No registered users and 22 guests
