B4 Subaru turbo replace
Postby 88.4ageGT » Sun Dec 15, 2013 1:02 am
Sorry i know its not a toyota but i thought you guys would know about this aswell
soo a friend of mine offered me a b4 subaru so less than 1000 but its got a blown turbo :/
soi just wanted to get thoughts on it. Car hasnt done many km has had a cam belt done and is in quite good condition
Is it worth buying?
how hard it to replace the turbo?
anything else i should check?
AE92 4age GTi
Building 3sge ae92 race car
Malcolm wrote:I didn't know they had maths on waiheke
88.4ageGT
Re: B4 Subaru turbo replace
Postby STR » Sun Dec 15, 2013 8:26 am
Any idea which turbo it was running?
Some Subaru turbos (made by IHI) are stupidly expensive. I had a VF38 on my KP60 and when I blew that, the only new one I could find in NZ was $2800...
IHI don't sell rebuild kits either.
82 KP60 4AGTE race car
S.T.R - Shopping Trolley Racing!!!
STR
Postby 88.4ageGT » Sun Dec 15, 2013 8:45 am
no not sure i was going to get a second hand one tho?
AE92 4age GTi
88.4ageGT
Postby Nuty|Mike » Sun Dec 15, 2013 8:50 am
B4 should be twin turbo ?
Usually quite cheap for second hand bits through www.subaruspeed.co.nz
05 Mazda Verisa .....for the Family
Nuty|Mike
Postby 88.4ageGT » Sun Dec 15, 2013 8:59 am
yeap twin turbo
AE92 4age GTi
88.4ageGT
Postby Dell'Orto » Sun Dec 15, 2013 10:04 am
Will be the primary turbo that's shot, should be able to get one from a wrecker for ~$300. Probably a day's work at home to swap?
Postby 88.4ageGT » Sun Dec 15, 2013 11:05 am
Dell'Orto wrote:Will be the primary turbo that's shot, should be able to get one from a wrecker for ~$300. Probably a day's work at home to swap?
Do you think a average person that knows alittle about cars could do the turbo swap or you really need to be a mechanic?
I just don't really wanna start something I cant finish
AE92 4age GTi
88.4ageGT
Postby Al » Sun Dec 15, 2013 11:08 am
I bet its got more issues than just a blown turbo.
Al
Postby Dell'Orto » Sun Dec 15, 2013 12:15 pm
It's just a matter of undoing bolts, it's not rocket science ;) Also test drive it first just to make sure that is it's only issue - they're not the most reliable of motors when they aren't looked after
Postby 88.4ageGT » Sun Dec 15, 2013 12:53 pm
ive driven it already. and the problem was the seal on the turbo intake side was leaking so oil was going into side when the turbo spooled up. so the garge that looked at it said
AE92 4age GTi
88.4ageGT
Postby strx7 » Sun Dec 15, 2013 9:15 pm
the going rate for a primary turbo weather it be a vf25, vf31 or vf33 is between 425+ gst through to $600+gst depending on which one it is.
Postby Dell'Orto » Mon Dec 16, 2013 9:45 pm
Really, better tell the local wreckers to up their rates then :lol:
Postby Lloyd » Mon Dec 16, 2013 9:47 pm
"But they're only $50 on trademe bro. You c***s are ripoffs as"
Postby Townace » Tue Dec 17, 2013 9:03 pm
"FUUUU thats expensive, I can get one for 1/3 that at Pickapart"
Townace
Users browsing this forum: Bing [Bot] and 3 guests
