Motul/TRD brake fluid
Postby Grrrrrrr! » Sat Jan 04, 2014 4:20 pm
Is north shore toyota doing this still? or how bout Mark? Trademe search shows nothing and i just ran out of RBF600 halfway thru bleeding after a master cylinder upgrade and need more.. supercheap doesn't carry this strangely enough.
Also, does anybody know if any of the racing fluids are a different colour.. like a red or green or something? would be good to be able to see when you've flushed the old stuff out....
Grrrrrrr!
Re: Motul/TRD brake fluid
Postby duddley » Sat Jan 04, 2014 6:01 pm
Doesn't Bazda sell Motul fluids?
i don't club seals..... only sandwiches
duddley
Postby matt dunn » Sat Jan 04, 2014 6:04 pm
Pretty sure he does.
Postby jaypines » Sat Jan 04, 2014 8:11 pm
Grrrrrrr! wrote:does anybody know if any of the racing fluids are a different colour.. like a red or green or something? would be good to be able to see when you've flushed the old stuff out....
theres ATE Racing Blue brake fluid but dont know where to get them. BNT also carries motul brake fluids.
On a related note anybody here used Castrol SRF racing fluid? Where to get them? apparently better fluid than motul.
jaypines
Postby Grrrrrrr! » Sat Jan 04, 2014 8:39 pm
Castrol SRF... Not sure I believe the price, but I do remember that sterling clutch and brake said the stuff was liquid gold.. And to think the FSAE team went through boxes of that stuff every year.
Grrrrrrr!
Postby QikStarlie » Sat Jan 04, 2014 10:00 pm
they should have the trd stuff on the shelf at toyota. they do in the whangarei branch anyway
QikStarlie
Postby 1I1 » Sat Jan 04, 2014 11:01 pm
We normally carry the TRD fluid in stock, out of stock ATM but will be getting more in.
TRD Clicky >>Here
1I1
Postby 2jayzgte » Sun Jan 05, 2014 1:18 pm
Isn't the TRD brake fluid just rebranded RBF 600?
2jayzgte
Postby Bazda » Sun Jan 05, 2014 1:57 pm
I have the RBF600 in stock. At my dads shop on the North Shore.
Postby Grrrrrrr! » Sun Jan 05, 2014 2:45 pm
Sweet, will pick some up from one of these fine gentlemen next week.
Grrrrrrr!
Postby atmosports » Sun Jan 05, 2014 3:09 pm
Else Hitech Motorsport in Drury have it in stock all the time & you can usually get it from BNT as well, BNT Takanini usually has either RBF600 or RBF660 on the shelf.
As for Castrol SRF, yes it is like Liquid gold & it does work but compared to Motul & the other good brands it's a lot more expensive. More so when you need to do a full flush with SRF to remove any traces of old fluid before your run it.
atmosports
Postby Mr Ree » Sun Jan 05, 2014 3:18 pm
I have found the TRD fluid to be priced better than the Motul, which I find odd.
wak thud gush!
Mr Ree
Postby 2jayzgte » Mon Jan 06, 2014 7:36 am
Expensive try AP Racing fluid now thats expensive at least 3 times the price of that Motul/TRD fluid.
2jayzgte
Postby Grrrrrrr! » Mon Jan 06, 2014 7:46 am
Pretty sure the Motul/Trd stuff is more than enough for what I want, hillclimbs and bent sprints in a 220ish HP car wont tax the brakes that much :)
Grrrrrrr!
