evil_si wrote:On the water feed pipes it will be ok, or you could use loctite Teflon pipe sealant
Edit, are you sure you have te right fittings? I haven't come across any turbos that use bsp or npt pipe fittings into the core for water lines, usually metric banjo type bolts and use sealing washers
