What type of tube to use for water hard lines?
Postby cat007 » Sun Oct 05, 2014 9:46 pm
Might end up making my own stainless hard lines for my 2JZ.
Just wondering what type of pipe should I use? Seamless, spiral welded?
Hunt
Re: What type of tube to use for water hard lines?
Postby Dell'Orto » Mon Oct 06, 2014 9:13 pm
I just used some seamless tube as it was easy to get. Doubt there will be much difference either way, the cooling system isn't going to see that much pressure
Postby cat007 » Mon Oct 06, 2014 9:17 pm
Dell'Orto wrote:I just used some seamless tube as it was easy to get. Doubt there will be much difference either way, the cooling system isn't going to see that much pressure
Thanks. where did you buy it from? was it steel and tube?
Postby Dell'Orto » Mon Oct 06, 2014 9:24 pm
Nah was from Milson Metals in Palmy, no doubt S&T would do it though. Is there an Anzor Fasteners up your way? They do all manner of stainless products
Postby cat007 » Mon Oct 06, 2014 9:54 pm
Dell'Orto wrote:Nah was from Milson Metals in Palmy, no doubt S&T would do it though. Is there an Anzor Fasteners up your way? They do all manner of stainless products
Yeah there is an Anzor up here. I'll hit them up. Cheers
Postby Malcolm » Thu Oct 09, 2014 10:43 pm
Why stainless? I used 1.6mm aluminium tube for all mine; lighter, easier to bend, swage, cut etc.
Postby touge_ae101 » Wed Nov 12, 2014 12:49 pm
Any type of stainless is fine. Only difference between seamless etc is hygienicness (we require it for some sterile dairy processes) and sometimes when we need a slightly higher bursting pressure. Seamed stainless around 6000psi, seamless can be up around 8-9000 psi depending on size of tube.
But I apart from being easie to weld/not having access to a ac tig, I think ali I'd the better option.
touge_ae101
Postby Bazda » Wed Nov 12, 2014 3:29 pm
All Alloy and stainless tubing in Auckland go to Tube Bending in East Tamaki!
They have all sizes and bends. And can cut you straight to any length.
Thye have bins out the front which are cheap, i've always been able to find most of what I needed in the bins!
ie. You buy a 'U' bend then you can chop it up to what ever angle you require.
