"Car Enthusiast" Project *PART TWO* updated
Postby slighty_looney » Sun Sep 30, 2007 7:59 pm
I thought id post up some pics of my dad doing up his S15 for you guys to have a look at, so far hes put a new end muffler on, taken out the cat and replaced it with 3" stainless, Then he built up a twin dump pipe (exhaust and wastegate split) he got a second hand s14 turbo to help him and he made up a custom jig, after a few trips home from work and some long nights he got it all tacked up
The car hasn't been dyno'd yet as hes going to do a front mount, new pipe work, pod filter/cold air box and finish off the rest of the exhaust in 3inch.
After welding up the dump pipe he sent it up to procoat in auckland and they heat ceramic coated it, heres the finished pictures
He bolted it back on last weekend and it made quiet a difference in the feel of the car, it feels more aggressive on boost and also comes onto boost alot faster and stronger then before, the boost level didn't increase and doesn't spike ether so hes very happy with the result. It also makes quiet a wicked exhaust note now, sorta like a external wastegate thats plumed back in but not as noisey. Tell me what you guys think as i think he done a pretty nice job :D
Last edited by slighty_looney on Fri Oct 26, 2007 6:53 pm, edited 1 time in total.
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby NILPSI » Thu Oct 04, 2007 6:10 pm
Looks good! I know who to come to if I need bits made :D
17 Triton - The "free supplied by work" daily
09 Aurion Sportivo - The Daily
97 Trueno BZ-G - The Garage Queen
97 Supra SZ-R - The never ending project... now with added boost!!
NILPSI
Postby Dell'Orto » Thu Oct 04, 2007 6:26 pm
I personally would have smoothed the welds off as much as possible, but it still looks nice 8)
Postby slighty_looney » Thu Oct 04, 2007 8:30 pm
Dell'Orto wrote:I personally would have smoothed the welds off as much as possible, but it still looks nice 8)
The welds are purged the welds aren't smoothed off because stainless has a habit of work hardening and cracking so they are left for extra strength 8)
FC3S
slighty_looney
Postby slydesigns » Thu Oct 04, 2007 10:56 pm
Come on Cole... Brad knows that, he's a technical expert. :lol:
Reminds me of people who smooth out Ali welds because they will look "nicer". No thought given to the welds strength. Had an idiot weld a swingarm for me that I had nearly sheared off freestyling and he ground the weld bead back! Took all the strenght away and it cracked within two weeks.
As always your dad's workmanship appears flawless.
[ADMIN EDIT: oversized sig image removed: 100px max height]
slydesigns
Postby Dell'Orto » Thu Oct 04, 2007 11:17 pm
Thought you'd be into looks Simon, given your sparkly green car and purdy hair :lol:
Postby slydesigns » Fri Oct 05, 2007 9:57 am
you'd think... but yeah.
slydesigns
Postby Snoozin » Fri Oct 05, 2007 10:00 am
^^^ Actually lol'ing at Samuel L in your sig bro.... :lol:
Snoozin
Postby slydesigns » Fri Oct 05, 2007 10:05 am
same reaction this end when i first saw it. Mr J has angry man syndrome
slydesigns
Postby IH8TEC » Fri Oct 05, 2007 3:51 pm
no flexi? i personally would have put a small flexi on the wastegate pipe EVEN THOUGH it's on the same flange as the dumppipe and a big flexi on the exhaust,. just seems to have a high potential to crack
otherwise i think it looks pretty good,
Postby slighty_looney » Fri Oct 05, 2007 4:46 pm
yeah thats true but it didn't have one from factory so saw no reason to put one in, id be very surprised if it cracked. but we will see how it goes, all good so far.
FC3S
slighty_looney
Postby TRDGT4 » Fri Oct 05, 2007 10:08 pm
tell ya old boy to bring the bi*ch out on the trackday and see how good it actually goes :wink:
TRDGT4
Postby slighty_looney » Sat Oct 06, 2007 11:55 am
yeah he should bring it out but he said he doesnt want to make us look bad. LOL he rung a few muffler centers etc bout the flexy idea and they said due to the motor being a "north south" engine it doesnt need one.
FC3S
slighty_looney
Postby Dell'Orto » Sat Oct 06, 2007 12:23 pm
The flexi on the wastegate pipe is a good idea though, as the sudden blasts of heat then cooling down make it expand and contract.
Postby slighty_looney » Sat Oct 06, 2007 9:06 pm
but its a solid item, its not like a external wastegate thats plumbed back in, plus with that procoat after going to quiet a hard drive you can hang onto the wastegate and dumppipe side without melting you're hands lol
FC3S
slighty_looney
Postby Si » Sat Oct 13, 2007 8:08 pm
that makes some sense to me. a north south engine moving would simply move the exhaust side to side. a east/west type upon moving would push/pull on the exhaust which would think is a worser thing than side to side movement.
Current: , '96 SubaruImpreza
Si
Postby Sideros » Sat Oct 13, 2007 10:58 pm
Flexis aren't just for movement of the whole muffler, can also be used for expanding and contracting with heat.
Sideros
Signwriter
Postby Truenotch » Mon Oct 15, 2007 12:34 am
Or making an exhaust fit easier when measurements are slightly wrong! :P
Truenotch
Postby matt dunn » Thu Oct 18, 2007 7:54 pm
I dont see a flexi as a requirement on a north south engine'd car normally.
Cant recall any from memory that had them from fatory.
Postby slighty_looney » Fri Oct 26, 2007 6:59 pm
hey guys, my dad finished the rest of his exhaust system on his S15 last weekend and sent it away, the hole lot now has been Heat Ceramic Coated from procoat in auckland. the pic shows the cat replacement and then the muffler from the cat back to the end muffler (not shown in pic) he also made a silencer in the middle to quieten it down abit :) the boost level with the complete system has gone from just under 10psi to 11psi, doesn't creep any higher and no other issues, goes alot better and has quiet a cool exhaust note.
FC3S
slighty_looney
Return to Palmerston North / Central North Island Region
Users browsing this forum: Bing [Bot] and 1 guest
