FX-GT vs. Levin vs. Trueno
What car?
FX-GT
5
36%
Levin
5
36%
Trueno
4
29%
Total votes : 14
Postby EVL GSXR » Thu Jun 16, 2005 12:45 pm
Going from his post above about being done for Careless Driving and the fact that he stacked a 4wd Celica (Not taking the piss dude just stating the Fact's) I think he would be better off with a Fwd FX - GT or something..
At the end of the day it's what you want dude so once your made your mind up go get what ever..
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Postby AJz » Thu Jun 16, 2005 1:39 pm
Erelyes wrote:Fuel economy? Bah!
Don't limit yourself to Toyotas... like has been said before, grab yourself a tidy S13/14, (n/a if you must...) will be plenty fun.
CA18 or SR20, your choice, SR powered ones are a little dearer, turbo motor does well enough, I wouldn't bother with an N/A CA tho.
Or a skyline, but a little less chuckable.
yea but the reason he crashed was cos he lost the back end, mabey start off in something like a little fxgt, master a fwd, then move to rear.
I had vtax :(
AJz
Postby Alex B » Thu Jun 16, 2005 2:55 pm
no offence but i stil dont know how the hell ytou can loose a 4wd. My car has too much traction i hate it!!!
Postby pervert » Thu Jun 16, 2005 2:59 pm
pyro_sniper2002 wrote:no offence but i stil dont know how the hell ytou can loose a 4wd. My car has too much traction i hate it!!!
:lol: :lol: :lol: :lol: :lol:
Bit of a difference between your Sprinter and a 2L turbo though...
pervert
Postby Alex B » Thu Jun 16, 2005 3:04 pm
:lol: verry true but still........4wd
n v my rear diff FWDers muhahahahahahahhahaahahahahah!!!111!!!
Postby SkylineObsession » Thu Jun 16, 2005 3:54 pm
Aren't Celica's AWD? Like Legacys, WRX's and EVO's?
I always classed them as AWD (always using all four wheels) and always classed Skylines a 4WD (using all four wheels only when the rear wheels lose traction).
SkylineObsession
Postby pervert » Thu Jun 16, 2005 3:56 pm
Mustang-man wrote:Aren't Celica's AWD? Like Legacys, WRX's and EVO's?
Aye???
AWD - All wheel drive
4WD - Four wheel drive
The difference being nothing, unless the AWD vehicle had more than 4 wheels I guess... :?
pervert
Postby SkylineObsession » Thu Jun 16, 2005 4:02 pm
No thats just something i heard/read somewhere. Wasn't sure about whether it was true or not.
SkylineObsession
Postby pervert » Thu Jun 16, 2005 4:03 pm
Don't believe everything you read, otherwise you might turn into Cozmo... :lol:
pervert
Postby AJz » Thu Jun 16, 2005 4:22 pm
pervert wrote:Don't believe everything you read, otherwise you might turn into Cozmo... :lol:
nice :P
only the gt4 celica's are AWD/4WD, mine definately aint :P
i would class the gt4's 4wd setup as being the same as a legacy, wrx, evo, what ever, the 4wd skylines (gts4,gtr) are slightly more rear based than the others. But ALL are still Four Wheel Drive
I had vtax :(
AJz
Postby SleepingGSR » Thu Jun 16, 2005 5:46 pm
My Gsr is classed a 4wd I dont think there is a difference between 4wd and Awd is there just a modern name :? Unless Awd distribute torque differently between all four wheels :? :? :?
Pyro im the same I cant seem to hardly get the gsr lose either :( *will try harder :twisted: *
SleepingGSR
Postby pervert » Thu Jun 16, 2005 5:49 pm
SleepingGSR wrote:Pyro im the same I cant seem to hardly get the gsr lose either :( *will try harder :twisted: *
Can I try? :twisted:
pervert
Postby SleepingGSR » Thu Jun 16, 2005 5:49 pm
Found this could be informative
ALL WHEEL DRIVE vs. 4WD
ALL WHEEL DRIVE:
Definition: A vehicle where all four wheels are driven, but there's no transfer case like a four-wheel drive rig. Most AWD setups are full time systems for year-round driving, and use a viscous fluid coupling center differential instead of a transfer case to route drive torque to all four wheels. This allows the front and rear wheels to turn at slightly different speeds when turning on dry pavement. Most folks do not consider this the same as four-wheel drive. It can be useful (and more fuel economical) in pavement driving where you're mainly negotiating bad weather conditions.
FOUR WHEEL DRIVE
Definition: A method of driving a vehicle by applying engine torque to all four wheels thru the use of a transfer case, differentials and hubs. Various schemes are used for 4WD including part-time, full-time and variable four-wheel drive. To help cut the drive train drag (and reduced fuel economy) that most 4WD's have, a transfer case is included that allows the driver to select either two- or four-wheel drive depending on driving conditions. Some performance cars have full-time variable four-wheel drive and use a computer-controlled transfer case to route power between the wheels.
It's important to note that even in 4WD, you still have only two driving wheels; one front; one rear. A normal passenger car is essentially one wheel drive, because the other one can slip. So a 4WD rig, with the front axle engaged, now has two wheels driving. Then if you add a locker to the rear, you've added one more wheel, to make your rig three-wheel drive. Add a locker to the front, so no tires can spin, and you have TRUE, 4-wheel drive, all four wheels driving.
:D
SleepingGSR
Postby Lloyd » Thu Jun 16, 2005 6:34 pm
I was under the impressoin Subaru claimed the term "All Wheel Drive" to be different from all the other 4WD vehicles or something along those lines. It is quite possible however that I'm talking arse
Postby rolla_fxgt » Thu Jun 16, 2005 6:35 pm
yeah that sounds right about the difference between the AWD & 4wd, but since most 4wd's seem to have lsd's of some sort or active transfer cases & all that new fancy help the bad drivers out type thing, i guess for all intents & puposeses, theres no real difference.
rolla_fxgt
Postby AJz » Thu Jun 16, 2005 8:02 pm
yea pretty much, lol
I had vtax :(
AJz
Postby 4ageman » Fri Jun 17, 2005 12:27 am
AWD/4WD evo's and wrx's and gtx'and gt4's dont have the powere evenly spread between front and rear. They all have a certain percentage of power going the the rear and the rest to the front.
4ageman
Postby Steelo » Fri Jun 17, 2005 6:46 pm
Im thinking this has gone off topic............... :roll:
2012 Subaru WRX
1985 Toyota Levin
2014 Yamaha MT-07
Steelo
Postby GGnz » Mon Jun 20, 2005 1:20 pm
Its called greasy roads... It even said this in the police report and I've told you this how many times now. If the road was completely dry like you keep suggesting I would of been sweet. Anyways who cares? I think every1 else is over it... :roll:
GGnz
Postby Distrb » Mon Jun 20, 2005 1:31 pm
oh dear, oh dear, oh dear.. you people cannot stay on topic, nor refrain from abusing people
:roll:
Distrb
Regular Poster
