meremere 7th Jan
meremere 7th Jan
Postby barryogen » Mon Dec 19, 2005 8:20 am
Anyone keen to go up? I am, but well, figuring that it'll be ~$450 each way to drive there, and pretty much the same to fly, I'm a little hesitant, and though that maybe some people here may want to "car-pool" up to it...
just either reply here or pm if interested.
barryogen
2ZZ Guru in training
Postby EVL GSXR » Mon Dec 19, 2005 8:32 am
Uuummm no dis-respect fella but if some people were saying they had no money to go to Timmer's and being just after Christmas/New Year's I don't think there will be many people keen if any..
Maybe I could be wrong..
www.lowndvs.co.nz
1997 GSXR750 - 11.23 @ 128mph to date - Round 280kph Top Speed to date
http://toyspeed.blakjak.net/profiles/profile.php?id=793
EVL GSXR
Postby no_8wire » Mon Dec 19, 2005 8:33 am
that for the import vs V8 battles?...it sounds good...
no_8wire
Postby barryogen » Mon Dec 19, 2005 10:03 am
no_8wire wrote:that for the import vs V8 battles?...it sounds good...
I realise that there may not be too many that are keen, hence why I'm not going as I can't afford it, but figured that given a few of us, we could make it up there fine(gas/4 = not too bad).
it does sound good.
barryogen
Postby iforgothowtodrive » Mon Dec 19, 2005 11:11 am
no thanks im using my money for summer nats dude
How Odd-No Darn Acceleration
iforgothowtodrive
Postby no_8wire » Mon Dec 19, 2005 11:43 am
Well I will be going...but I will be in Opoutere anyway which is les than 1.5 hrs away
no_8wire
Postby barryogen » Tue Dec 20, 2005 3:56 pm
never mind, not going... engine just went "bang"...
I don't know enough about it to try to even describe what went wrong, but it smells electrical(like busted capacitors if anyone has smelled that).
It is running, but until I find out what it was(being checked tomorrow), no big trips are gonna happen, Check engine light is flashing intermittantly(like it wants to flash constantly but has a loose wire).
Go the auto Rav4 for work...
barryogen
Postby Alex B » Tue Dec 20, 2005 7:28 pm
it will flash a code but im not sure where the diagnostic plugs are on new skool toyotas, possibly only can be done by toyota.
Postby barryogen » Wed Dec 21, 2005 7:24 am
pyro_sniper2002 wrote:it will flash a code but im not sure where the diagnostic plugs are on new skool toyotas, possibly only can be done by toyota.
The smell is coming from a scortch mark on the alternator, it is still charging, the light has stopped flashing and the car is going fine.
There is a fried wire that appears to have come lose from somewhere(?), and hit the alternator(hence the scortch marks) and it heads into the firewall, will need to find out where it goes, although it looks to be buggered, and doesn't seem to affect anything.
barryogen
Postby barryogen » Thu Dec 22, 2005 11:16 am
barryogen wrote:The smell is coming from a scortch mark on the alternator, it is still charging, the light has stopped flashing and the car is going fine.
Not quite sure on how it happened, but the wire appears to be the one for the water temp/radiator fan sensor, currently the fan on the radiator is going hell for leather all the time(not that big of a deal), but if I hookup a wire to replace the scortched one(some of the copper is bubbled, so current must have been high), it goes back to only being on when I abuse the car.
Still getting it checked out properly(auto-electrician mate was busy the other day), just not too sure when.
Wire heads(eventually after doubling back a few times) to the ECU, I'm re-soldering it(new wire) on this arvo.
"it'll be fine" - famous last words.
barryogen
