www.DrivenPerformance.co.nz brings you a very special pre-release oppertunity to purchase the new MAP ECU II !!!!
These units will not be released until January at the earliest - and this is your chance to pre-order and save!
These units will sell for $1000+gst a piece, but as part of this group buy you can pre-order yours for $899+gst !
This is a fantastic price for a computer with this level of functionality! Even a cheap electronic boost controller is nearly $400 a piece - well with the MAP-ECU II this comes built in!!! Anyone thinking of purchasing an ECU anytime in the next 12 months should seriouslly consider this deal!
Features of the all new MAP ECU 2 include:
• Fuel control and Air Flow Meter replacement
• Timing control with +/-30 degrees adjustment
• OEM O2 sensor voltage adjustment
• Auxiliary Injector control
• Electronic Boost Control with ten (10) zones every 1000 RPM
• 0-10,000 RPM. 200 rpm increments 0-2000, 500 rpm increments 2000-10,000 for Fuel and O2 Adjust tables. 500 rpm increments 0-10,000 for Timing and Auxiliary Injector tables.
• Built-in MAP sensor, +35 PSI. Pressure scale is user configurable using a MAP-CAL.
• Frequency based Speed Cut Defender (SCD).
• Frequency based Speed Adjust
• Voltage based Fuel Cut Defender (FCD)
• Launch Control - Target RPM and Clutch Switch input.
• Two Complete (2) maps (Primary/Secondary) for Fuel, Timing, Auxiliary Injector, O2 Adjust & EBC - selectable using one of the configurable inputs.
• Support for optional external MAP sensor input.
• Plug compatible with current MAP-ECU harness.
• Three (3) multi-function high current switched outputs configurable as follows:
• NOS solenoid drive
• RPM>0
• Pressure Switch
• RPM Switch
• EBC
• Upgradeable software stored in Flash memory that can be downloaded using MAP-CAL. Does not require removal of MAP-ECU2 from vehicle.
Details:
This is a group buy / pre order. To place your order you will need to:
1) Email us at sales @ drivenperformance.co.nz with your name, delivery address and phone number. We will then email you back a copy of your invoice.
2) You must then immediately pay your deposit ($300 deposit required)
3) When production is complete in Jan-Feb 2007 you will have pre-reserved units.
4) Once the units are ready, we will email you requesting the balance of payment.
5) Upon recipt of this payment we will courier your new MAP ECU II kit out to you!
