MAP ECU II - SPECIAL ADVANCED PROMO GROUP BUY!!!
Postby TWSTD » Fri Dec 08, 2006 3:27 pm
www.DrivenPerformance.co.nz brings you a very special pre-release oppertunity to purchase the new MAP ECU II !!!!
These units will not be released until January at the earliest - and this is your chance to pre-order and save!
These units will sell for $1000+gst a piece, but as part of this group buy you can pre-order yours for $899+gst !
This is a fantastic price for a computer with this level of functionality! Even a cheap electronic boost controller is nearly $400 a piece - well with the MAP-ECU II this comes built in!!! Anyone thinking of purchasing an ECU anytime in the next 12 months should seriouslly consider this deal!
Features of the all new MAP ECU 2 include:
Fuel control and Air Flow Meter replacement
Timing control with +/-30 degrees adjustment
• OEM O2 sensor voltage adjustment
Auxiliary Injector control
Electronic Boost Control with ten (10) zones every 1000 RPM
• 0-10,000 RPM. 200 rpm increments 0-2000, 500 rpm increments 2000-10,000 for Fuel and O2 Adjust tables. 500 rpm increments 0-10,000 for Timing and Auxiliary Injector tables.
• Built-in MAP sensor, +35 PSI. Pressure scale is user configurable using a MAP-CAL.
• Frequency based Speed Cut Defender (SCD).
• Frequency based Speed Adjust
• Voltage based Fuel Cut Defender (FCD)
Launch Control - Target RPM and Clutch Switch input.
• Two Complete (2) maps (Primary/Secondary) for Fuel, Timing, Auxiliary Injector, O2 Adjust & EBC - selectable using one of the configurable inputs.
• Support for optional external MAP sensor input.
• Plug compatible with current MAP-ECU harness.
• Three (3) multi-function high current switched outputs configurable as follows:
• NOS solenoid drive
• RPM>0
• Pressure Switch
• RPM Switch
• EBC
• Auxiliary Injector
• Upgradeable software stored in Flash memory that can be downloaded using MAP-CAL. Does not require removal of MAP-ECU2 from vehicle.
Details:
This is a group buy / pre order. To place your order you will need to:
1) Email us at sales @ drivenperformance.co.nz with your name, delivery address and phone number. We will then email you back a copy of your invoice.
2) You must then immediately pay your deposit ($300 deposit required)
3) When production is complete in Jan-Feb 2007 you will have pre-reserved units.
4) Once the units are ready, we will email you requesting the balance of payment.
5) Upon recipt of this payment we will courier your new MAP ECU II kit out to you!
@@@ Online store NOW OPEN! @@@
Click here!
DPR | HTS | SARD | WALBRO | GARRETT | SPEC | EXEDY | MINTEX | HKS | APEXi | MAPECU | SIMOTA + more!
TWSTD
Postby Santa'sBoostinSleigh » Fri Dec 08, 2006 4:35 pm
suitable for 20v 4age turbos?
Santa's Mega Sale
Santa's TardMe Listings
GTFX: viewtopic.php?t=67655
Postby TWSTD » Fri Dec 08, 2006 10:42 pm
Sure :-)
Click here!
TWSTD
Postby Silent Knight » Sat Dec 09, 2006 12:03 pm
This is a full replacement ECU or a piggy back?
Sorry I couldn't quite figure out from the above...
If it's a piggy back I'll definitely be keen to jump in on the action.
Silent Knight
Postby TWSTD » Sun Dec 10, 2006 9:09 am
Yes - as with the 1st edition this is an intercept style unit - so you can use as many or as few of the features as you require!
Click here!
TWSTD
Postby TWSTD » Mon Feb 12, 2007 11:18 am
This pre-order will be wrapping up by the end of this month - so those that still want one and have not sent in their deposit please act NOW! :-)
AL
Click here!
TWSTD
Postby TWSTD » Wed Mar 14, 2007 3:57 pm
This pre-order has now finished. Many thanks to those who partook - your units will be shipped to you shortly!
I am happy to run a groupbuy in the future if we can get an order of at least 5 units together. I will also be using one of these in my own race car in the not too distant future.
All the best!
AL
Driven Performance LTD
www.drivenperformance.co.nz
Click here!
TWSTD
Postby TWSTD » Thu Sep 06, 2007 3:43 pm
We can now once again offer these great little computers for $899+gst! Mention you are a TS member when ordering via the Driven Performance online store and you will get free freight nationwide too!
For those who are interested I am running one in my own race car and have dyno sheets for anyone who wants to see the gains we made!
AL
Click here!
TWSTD
Return to Toyspeed Sponsors
Users browsing this forum: Bing [Bot] and 1 guest
