Moroso Baffled Sumps
Postby Bazda » Sun Jan 20, 2013 9:38 pm
Hi Guys,
We are currently putting together an order for Moroso Products.
Most guys here would prob be interested in the Baffled sumps.
We can do any of their sumps just post up what your after.
Their stocked sumps for Toyotas are 3sge/te and 3TC
Engine Application: Model #3SGT 2.0L Turbo and 5SFE Non-Turbo
Fits: 1990-95 MR2, Celica and All Track
$579
Aluminum with 1/4" thick billet aluminum pan rail
Trap door baffling ensures adequate oil control
Solid windage tray with oil drain & dipstick cut out holes prevents oil from splashing back to the rotating assembly, robbing vital horsepower
Front of pan includes a 28mm threaded bung to accommodate the factory turbo drain back connection
Side of pan retains a 3/8" thick billet receptacle to accommodate the factory oil level sensor
Includes mounting kit with hex drive steel studs and serrated faced flanged nuts
Engine Application: 3C, 2T and 2C engines For engine swaps, check dimensions for clearance $649
One piece, 1/4" thick billet aluminum pan rail provides a rigid flange for leak-free sealing
Trap door baffling
Louvered windage tray maximizes horsepower and de-aerates oil
A separate sump tray helps prevent oil from splashing back and also de-aerates oil returning from the turbo
Includes (2) 1/2" NPT bungs for plumbing turbo oil return line and installing oil temperature sender.
Two magnetic drain plugs facilitate oil draining when the engine is canted left or right
Includes mounting kit with hex-drive steel studs and serrated-face flange nuts
Also we are currently working with Moroso to create a 4age sump to suit FWD/RWD etc. All models.
These will be $550
Postby Vertigo » Thu Jan 24, 2013 8:01 am
let me know when the 4AGE sump is ready, keen
TVIS just kicked in, yo!
Vertigo
Postby stalker » Thu Feb 28, 2013 11:51 pm
Hey dude,
Im keen for one of these for a 4AGE.
Let me know when you want some moola
8)
AE85.6 Levin - Project car Click Here
RZ Supra formully known as EMZ RZ
stalker
Postby stolic » Fri Mar 01, 2013 7:26 am
Guess I'll need something for the 9a...
Count me in too :lol:
ImageTA22-build - TA22-blah
I envy those with little interest in cars, for they have money and spare time.
stolic
Postby Bazda » Fri Mar 01, 2013 7:45 am
stolic wrote:Guess I'll need something for the 9a...
Noted down.
Postby Bazda » Sat May 04, 2013 10:31 am
Sneaky peaky picture of the sump so far
Return to Toyspeed Sponsors
