We are currently putting together an order for Moroso Products.
Most guys here would prob be interested in the Baffled sumps.
We can do any of their sumps just post up what your after.
Their stocked sumps for Toyotas are 3sge/te and 3TC
Engine Application: Model #3SGT 2.0L Turbo and 5SFE Non-Turbo
Fits: 1990-95 MR2, Celica and All Track $579
Aluminum with 1/4" thick billet aluminum pan rail
Trap door baffling ensures adequate oil control
Solid windage tray with oil drain & dipstick cut out holes prevents oil from splashing back to the rotating assembly, robbing vital horsepower
Front of pan includes a 28mm threaded bung to accommodate the factory turbo drain back connection
Side of pan retains a 3/8" thick billet receptacle to accommodate the factory oil level sensor
Includes mounting kit with hex drive steel studs and serrated faced flanged nuts
Engine Application: 3C, 2T and 2C engines For engine swaps, check dimensions for clearance $649
One piece, 1/4" thick billet aluminum pan rail provides a rigid flange for leak-free sealing
Trap door baffling
Louvered windage tray maximizes horsepower and de-aerates oil
A separate sump tray helps prevent oil from splashing back and also de-aerates oil returning from the turbo
Includes (2) 1/2" NPT bungs for plumbing turbo oil return line and installing oil temperature sender.
Two magnetic drain plugs facilitate oil draining when the engine is canted left or right
Includes mounting kit with hex-drive steel studs and serrated-face flange nuts
Also we are currently working with Moroso to create a 4age sump to suit FWD/RWD etc. All models.
These will be $550
