AE101Z wrote:just wondering can a 4agze install a boost controller? and the standard boost of ae101 sc
JiNX wrote:AE101Z wrote:just wondering can a 4agze install a boost controller? and the standard boost of ae101 sc
Standard boost is around 8psi, and since boost is controlled by the size of the crank pulley, no a controller is not a usefull idea...
AE101Z wrote:Lanius wrote:Belt slip? Do you hear a squealing noise at all when you go over 4 or 5000rpm?
i think that is the problem, so do i just need to change another shorter belt??
