Wellingtonians your opinion please
Postby Elmendorf » Tue Apr 20, 2004 5:57 pm
Ok so my car is now mobile again clutch is done as is every thing else engine wise.
Only thing needing doing now its the turbo. So does/has anyone in the Wellington area had their turbo reconditioned :?: If so where did you go, how good was the work and how much did it cost.
Thanks
Elmendorf
Postby B1NZ » Tue Apr 20, 2004 6:50 pm
Why not just go for something a bit bigger, i've heard starlys go real well with a bigger one slapped on there :wink:
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Elmendorf » Tue Apr 20, 2004 7:14 pm
Yeah I would but to be honest cant afford all the added extras that go along with a bigger turbo :cry: Its cost me a minor fortune to get the car mobile again and really cant justify the expense at the present time as I am trying to get out of debt after being unemployed for several months.
Elmendorf
Postby Loudtoy » Tue Apr 20, 2004 7:19 pm
Don't know how much ct9's are worth so we shall start with $100 which will be cheaper than getting it reconditioned! I will let you know what kind of condition it is in after we get it off the car in about 2 weeks or so! If i think it's mint i'l send it down to you and you can get it checked over by a turbo specialist??
Let us know what you want to do and i'l get back to you about it :)
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
Postby Elmendorf » Wed Apr 21, 2004 12:12 am
Will consider it if it is in good condition. Let me know how many km's its done, if its from a manual or auto and also if there is any sign of smoke when the car is idiling etc as I currently have 2 ct9's that have stuffed seals only.
Thanks
Elmendorf
Postby Loudtoy » Wed Apr 21, 2004 7:44 pm
Harlet wrote:Will consider it if it is in good condition. Let me know how many km's its done, if its from a manual or auto and also if there is any sign of smoke when the car is idiling etc as I currently have 2 ct9's that have stuffed seals only.
Thanks
Auto done about 110kms i think doesn't smoke or anything at idle no sound when spooling and hasn't (as far as i can tell from actuator hoses etc) had the boost wound up on it by any means other than the increase found by a 2 1/2 inch exhaust! Runs 10psi all day at the moment might be a couple o weeks before it's off the car as we have to get the money together to get the standard exhaust manifold modified slightly to take the new turbo!
TS Member sine 2001
Loudtoy
Postby Rollin' » Wed Apr 21, 2004 10:26 pm
pulsar gti-r turbos run very well on the starlet.
AE82 16.4 @136kph
ex:AE80 dx sedan, the green machine
corrola's are for life:
not just for christmas!
http://toyspeed.blakjak.net/profiles/profile.php?id=166
Rollin'
Postby Al » Wed Apr 21, 2004 10:57 pm
Rollin' wrote:pulsar gti-r turbos run very well on the starlet.
Add the price of the new manifold, the moving of oil lines, removing a/c.....
Al
Postby Rollin' » Wed Apr 21, 2004 11:36 pm
ok point taken,
i dont get told everything. but with other mods, 1990 starlet did 187kw at the wheels, and traction was an issue.
AE82 16.4 @136kph
Rollin'
Postby e30-323ti » Thu Apr 22, 2004 10:04 am
SR Auto's in Upper Hutt Rebuilt and highflowed the T25 I had on my GTX for $300.
If your CT9's are in good cond, and only need seals I imagine it would be half that (depending on the price of seals for the toyota turbo).
I also heard the mitsi TD04's bolt onto the 4EFTE exhaust manifold, might be worth looking into as they are quite cheap and easy to get ahold of.
e30-323ti
Postby AXNGRL » Thu Apr 22, 2004 10:16 am
:o DO NOT & I REPEAT DO NOT go to SR Automatics
They are the people (Sheldon) who did my turbo, extended the shaft using a bolt that wasn't balanced. It absolutely ruined my first turbo...
Sad really cause my dad knew him & recommended him, however after the appalling job he did on mine, there is no way either of us will ever go back....
Also, I thought you got that turbo I sold you checked out??
AXNGRL
Postby Elmendorf » Thu Apr 22, 2004 6:48 pm
Yep got the turbo checked Kristal, which is why I'm 100% sure its only the seal, of which I have the kit for both turbos already courtsey of tatsumaki racing :D
But yeah not looking at upgrading the turbo atm as I dont have the dosh to buy the custom mani I need. Stock manis on these puppies are crap when it comes to up boost or putting a different turbo on them. That aside it would take my mate several weeks to make the mani and send it down to me. So really just waning somewhere that does a good job for a reasonable price.
Elmendorf
Postby e30-323ti » Fri Apr 23, 2004 11:04 am
AXNGRL wrote::o DO NOT & I REPEAT DO NOT go to SR Automatics
That is interesting, he did a really good job on my T25.
e30-323ti
Postby AXNGRL » Fri Apr 23, 2004 1:10 pm
He probably did, but he absolutely ruined mine all because he didn't make sure the washer was balanced, that he used to space out my shaft to get the compressor wheel to fit...
AXNGRL
