ke70 axles - ke20 diff
Postby GT-WGN » Fri Jun 25, 2004 6:17 pm
hey before starting this job i was told the ke70 axles were 5mm longer than ke20 ones but now ive pulled the axles outa the ke70 diff and there 3-4cm longer
im just wondering how do i shorten the axles get them machined or sumthing
any replies will be appreciated
GT-WGN
Postby NZ_AE86 » Fri Jun 25, 2004 7:34 pm
NZ_AE86
Postby NZ_AE86 » Fri Jun 25, 2004 7:35 pm
Hey,
Work out if there will still be enough spline to go into the spider gears, if so then you can get the ends cut off. I have done it myself a few times, the Axles in my AE86 Race car have been cut as they were non LSD axles.
If the spline is not long enough you can get this spline machined further on the shaft then cut to the correct length.
NZ_AE86
Postby GT-WGN » Sat Jun 26, 2004 6:26 pm
year nar the splines wont be long enough once i cut them is it expensive to get them machined to suit the ke20 ones
GT-WGN
Postby NZ_AE86 » Sat Jun 26, 2004 9:38 pm
As long as the splines just need to be extended I can't see it costing more then 50 bucks a side.
I have the phone No. at work of the dude who can cut the splines. I will get it tomorrow for you. If you give him a call he will be able to give you a price.
NZ_AE86
Postby Dunny » Sun Jun 27, 2004 2:29 am
What u talkin about Willis :lol: most ke20 diffs are b code 5.7" so u code ke70 wont even fit into the side gears :p
Have ya checked that?
Dunny
Postby wde_bdy » Sun Jun 27, 2004 1:41 pm
Dunny wrote:What u talkin about Willis :lol: most ke20 diffs are b code 5.7" so u code ke70 wont even fit into the side gears :p
You need to put the KE70 U code centre in as well, and before you consider resplining the axles you may find the axle is too narrow after the spline to be able to. I think you need U code Starlet axles.
Callum
wde_bdy
