4a-gze internals...
Postby ants_ae92 » Tue Aug 03, 2004 11:55 am
great way to stop burning oil in a4age, oil catch tank. That will stopit burning oil, especially at high rpm
ants_ae92
Postby Mr Revhead » Tue Aug 03, 2004 12:08 pm
But i am contemplating a gze crank and conrods for more strength, any objections??
yes!! just to clarify in case theres any confusion....
REDTOP SMALL PORT CRANK AND RODS ARE THE SAME AS 4AGZE.
4AGE CRANK AND RODS ARE THE SAME AS COROSPONDING YEAR 4AGZE. (this includes the 20v)
the main difference is aw11 and early ae92 4agzes which have the low comp pistons and different rods from the later 4age/zes
so to answer your original question, yes 4agze forged pistons will go in you 4age no problem. BUT they are suitable for forced induction only.
if you have a blue top or early awll engine then you need to change the rods and crank to fit the 4agze pistons.
Postby kingcorolla » Tue Aug 03, 2004 6:36 pm
im happy 2 save my cash and stick with factory redop internals. Mines a small port and just wanted to see if 4a-gze crank and rods would improve big- end strenth, didnt know they were exactly the same!
1983 Carina AA63 4age
kingcorolla
Postby Mr Revhead » Wed Aug 04, 2004 11:36 am
yup they are, best thing you can do to improve strength is use ARP rod bolts, as the factory ones are the weakest link in the bottom end, but it depends on what you are using it for, ARP ones would suit something that is being revved hard constantly. i can do them for about $110 a set
then theres TRD bearings if your rebulding it
Postby kingcorolla » Thu Aug 05, 2004 2:51 am
yep im keen on the big end bolts. Ill let u know when.
the bearings sound like a winner too.
is there like a catalogue or a website i can see 2 view all TRD has to offer??
i try 2 find it on the internet but all i find is
http://www.trdsales.com
which is quite a shit site 4 sumone like me whos doing a rebuild and wants to go THE WHOLE NINE 8)
kingcorolla
Postby Mr Revhead » Thu Aug 05, 2004 11:38 am
yeah not much info there.
try:
http://trdparts.jp/
youll need to translate it as its all japanese
there is/was an english site there but theyve either changed its location or killed it and neglected to tell us! :evil:
i have all the bearing info here though
Postby AceSniper » Thu Aug 05, 2004 12:13 pm
AceSniper
Postby Mr Revhead » Thu Aug 05, 2004 2:12 pm
thats the old one. some stuff there is no longer available.
iv found the current english one. try:
http://trdparts.jp/english/index_menu.html
8)
Postby kingcorolla » Fri Aug 06, 2004 2:31 am
minta. cherz 4 the mint site guys.
even got the part numbers on there!
kingcorolla
Postby Mr Revhead » Fri Aug 06, 2004 5:34 pm
no problem, just let me no which ones you want and ill sort you out 8)
Postby kingcorolla » Fri Aug 06, 2004 7:23 pm
ye im keen on those big end bolts.
would have to post to chch tho.
im still keen tho.
have to try and trak down those TRD bearing shells, the got both big end & main bearings ay?
kingcorolla
