3SGTE into AE85
3SGTE into AE85
Postby Rivit » Mon Sep 20, 2004 11:02 am
Does this engine fit? how much cutting/modification to the engine bay will have to be done? I saw on serious performance 7 a dude with a ae85 trueno with a 3sge and his engine bay didn't look to be cut in anyway.
would it be cheaper in terms of power vs. cost to put the 3sgte instead of the 4age turbo?
Rivit
Postby dragonx » Mon Sep 20, 2004 11:38 am
the 3SGTE in the sillycar, mr2 and caldina is slanted over a bit, u would prolly have to correct this (making the engine sit strait), i assume engine oiling issues may be a problem after? the engine mounts on the block are not in the best location for this setup either (from memory)
now u need a gearbox that will fit as the above cars were not FR cars.
maybe the 3S conversion you saw was from a altezza, which has a north south non slanted engine, u might even be able to use the gearbox as well. im sure the cost would be a real issue though and its not a turbo engine soo.......
dont know if it would fit.. i assuem not very well without a lota help from MR blowtorch.
so im thinking a turbo 4age would be a bit cheaper option
In the Land of Dunedin
dragonx
Postby Ae92typeX » Mon Sep 20, 2004 12:07 pm
Ive seen afew articles on a 1G fitted into them (6cyl) so a 3s will for sure. Theres been quite afew discussions on bellhousings and mods required to convert to rwd, and while being a fair amount of work it is for sure do-a-ble.
Someone on here had a 3s-w5# bellhousing for sale a while ago.
as well as your standard break, fuel line, puta/loom mods you may need to modify the crossmember, but Im not sure.
Ae92typeX
Postby vvega » Mon Sep 20, 2004 12:33 pm
to be honest id go with the 4age turbo
just allows you to spend more on the gogo side and less on the cut cut and cert
v
vvega
Postby Dori_85 » Mon Sep 20, 2004 7:39 pm
sr20det, cough :lol: .
current: s14 silvia k's.
previous: ae85 levin 4agte, rt84 corona, kp61 starlet.
Dori_85
Postby matt dunn » Mon Sep 20, 2004 9:38 pm
vvega wrote:to be honest id go with the 4age turbo
v
And because you can just about go and just buy all the bits to make a 4age fit which makes meverything a lot easier.
Postby Scottie » Mon Sep 20, 2004 10:37 pm
Scottie
