What should I be paying for Shocks
Postby darkman0101 » Wed Sep 29, 2004 3:20 pm
One of my rear shock is stuffed.
It will compress fine but is real slow on the rebound stroke.
Sometimes it frees up but if you bounce th car a couple of times it will lock up.
Apparently one of the valves might be jammed/blocked.
I have left it since changing the brake calliper in the hope it would come right but it hasn't.
Therefore,
what is a set of shocks gonna set me back?
I could go for a nice set of sporty adjustable type jobbies.
AE92 Toyota Corolla FXGT (1990).
Cheers,
Jas
darkman0101
Postby Mr Revhead » Wed Sep 29, 2004 3:27 pm
your options are limited only by your wallet!!
ill pm ya some deals :wink:
Re: What should I be paying for Shocks
Postby Bling » Wed Sep 29, 2004 5:02 pm
darkman0101 wrote:I could go for a nice set of sporty adjustable type jobbies.
must have bucket loads :P
$600 is the cheapest I got for 4 shocks, i'm guessing you will replace them all?
Postby ROBODISCO_20v » Sat Oct 02, 2004 2:25 pm
Average retail price for monroe GT Gas replacement strut is $180ea so there's a starting point for you.
ROBODISCO_20v
shocks
Postby SkunkWeRX » Sat Oct 02, 2004 7:51 pm
i got some KYB gas ones today from supacheap for $476 all up
i think that was pretty good
SkunkWeRX
Postby atmosports » Sat Oct 02, 2004 9:01 pm
KYB replacement's for stock units start at around $100 a corner, think I paid $80 each for my last ones direct from stocks. Monroe's etc will start about the same so probably $400-600 a set plus maybe a little more for fitting if you can't do it yourself.
Single Adjustable Koni's or Non adjustable(no bump/rebound adjustment, height only) bilsteins are around $500 a corner depending on the car or $2000 a set. Advantage here is you get a way better shock for your money & these can be rebuilt/revalved rather than throwing them away.
Double Adjustable Koni's, adjustable bilsteins(yes they do them), teins, DMS, AVO, Leda, Proflex, Ohlins etc are from $2000 a set upwards depending on how serious you want to go, i.e. remote reserviors/alloy bodies etc add to cost but these are really a waste of time unless you seriously using your car for track work & KNOW how to set them up PROPERLY.
atmosports
Users browsing this forum: No registered users and 44 guests
