Knock Knock, Whats that noise!?
Postby marke » Sat Nov 13, 2004 8:22 pm
Hi all,
well there is a weird knocking coming from (ae101 levin) the "back" of the car, i swear its the back. ive had the cv's checked, its been to 3 different mechanics... basically they cant fix it? occurs mainly when i turn corners under a bit of throttle. i dropped it into a place last week and said just fix it, after $500 of "rear left wheel bearing replacement" it still didnt fix it, i brought it back and they spent a day going over "every bolt" basically this didnt fix it either. He said pretty much "dont come back if it doesnt fix it cause i dont know what to do" the speed of the knock is dependant on the speed of the conering too. anyone had something like this? i saw a topic re: another noise but that was in a straight motion not cornering..? well all help is appriciated!
Mark
No this is me in a nutshell..
"help im in a nutshell, how did i get into this bloody great nutshell... what kind of nut has a shell...like this.."
marke
Postby Ae92typeX » Sat Nov 13, 2004 8:26 pm
Probably not, but have you checked you exhaust mounts?, one of me other cars used to get a funny knock when cornering, ended up being the exhaust just tappin the side
Ae92typeX
Postby Caveman » Sat Nov 13, 2004 8:26 pm
Are the tools for changing a tire secured? If not they can make a hell of a noise rattling around inside the panel. May sound kinda noobish but it may just fix your problem :D
AW11 Track Toy
Formerly known as 1998
Caveman
Postby levin_it_large » Sun Nov 14, 2004 11:11 am
yeah sounded like it would have been a collapsed wheell bearing, maybe its ur hub??
levin_it_large
Postby badidas » Sun Nov 14, 2004 11:30 am
if your in auckland take it to petermark automotive i used to work for them they"l be able to sort it out
id have a go but im flat tack at the moment so yeah there in glenfield give them a buz numbers in the book
1989 mazda bongo aka [BNGBUS]
badidas
Postby aesc » Sun Nov 14, 2004 11:51 am
Have you got 17's on ya car and have just recently got it lowered or got new tyres or alignment or something? Had the same problem on mine when i first got it lowered. Ended up that the wheel balance weight had been put on the inside of the rim of one of the rear wheels and was knocking on the strut tower. That would explain the noise when going round corners and is speed dependant.
EX AE101 owner
2013 Ford Focus ST
aesc
Postby marke » Sun Nov 14, 2004 2:45 pm
i think the tools are locked up tight, someone said the back bumper but i took that off and tightened it all up.
cheers for the suggestions i'll try them out ive been told its all safe and it always passes wof's
thanks for the responses
mark
marke
Postby B1NZ » Sun Nov 14, 2004 11:20 pm
check rear swaybar bushes, my AE111 had a similar noise but the bushes were all fixed and now its fine
Subaru GF8 Wagon
Subaru GC8 rally car project
B1NZ
Postby Just_Juzz » Mon Nov 15, 2004 7:47 am
B1NZ wrote:check rear swaybar bushes,
I concur, your can tell easily if they are $&#$%, they'll be outta shape, or perished.
Cheep fix.
Current Ride: 1998 Caldina GT
Me, me, me, me.....
Just_Juzz
Postby Digitizar » Tue Nov 16, 2004 2:01 pm
Just_Juzz wrote:I concur, your can tell easily if they are f****d, they'll be outta shape, or perished.
Cheep fix.
mine had the noise with the bushes, but they looked like they were new. i had to get under the car (while not jacked up, cos if u jack it up on one side the sway bar is in use), and just pull on the sway bar, that made noise. changed the bushes - got rid of the noise. the bushes is a common problem on corollas/sprinters
AE111 Levin Light man a fire and u'll keep him warm for a day, light a man on fire and u'll keep him warm for the rest of his life..
Digitizar
