low end power of blacktop
Postby phatman3801 » Sun Jan 09, 2005 6:10 pm
i have a 1997 levin bzg with a blacktop..i have alwys knowen the low end power range isnt the best in the blacktops but a frind has jst got a bz touring with a black top and has a lot more low end power! much more than mine and is also standard! also i have let sumone i no who has had a lot of levins drive mine and he reckns a silvertop has better low rev power than mine..sooo im guessing sumthing is wrng with mine any thing u think it would b thats making my power not as good as wot it should be?? ne help would b gd! cheerz
phatman3801
Postby vvega » Sun Jan 09, 2005 6:46 pm
do a compression test on both cars and compare
v
vvega
Re: low end power of blacktop
Postby CozmoNz » Sun Jan 09, 2005 8:13 pm
phatman3801 wrote:i have a 1997 levin bzg with a blacktop..i have alwys knowen the low end power range isnt the best in the blacktops but a frind has jst got a bz touring with a black top and has a lot more low end power! much more than mine and is also standard! also i have let sumone i no who has had a lot of levins drive mine and he reckns a silvertop has better low rev power than mine..sooo im guessing sumthing is wrng with mine any thing u think it would b thats making my power not as good as wot it should be?? ne help would b gd! cheerz
you sure they are both completely stock?
eg if yours has aftermarket headers you dont know, that will be your culprit etc.
just be certain they are both stock. and as vvega said, do compression test :)
Rayne For President!
CozmoNz
Postby EVLGTZ » Sun Jan 09, 2005 8:43 pm
both running same timing? would make a world of difference if not that similar
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby matt dunn » Sun Jan 09, 2005 10:25 pm
EVLGTZ wrote:both running same timing? would make a world of difference if not that similar
exactly. Timing makes all the difference to them.
And do you both run the same fuel?
Matt
Postby 10k 20v » Sun Jan 09, 2005 10:54 pm
if none of the other suggestions clear anything up.....
i'd be checking the vvt solenoid wiring and solenoid, if that seems to be working fine then check the pulley for seizure. it is also possilbe the oil gallery to the pulley could be blocked as to the poor state that some of those engines come into the country. (lack of servicing)
the vvt gives you your bottom end torque & power
10k 20v
Postby phatman3801 » Thu Jan 13, 2005 10:35 am
ok im gunna check my timing..is it best to run these engines with advanced timing? or jst run the timing standard?
phatman3801
Postby EVLGTZ » Thu Jan 13, 2005 12:14 pm
Could possibly advance it a couple of degrees if ya like for a lil more low down power and response if your running higher rated gas like 98 but hey cant really go wrong with the stock settings.
EVLGTZ
EVLGTZ
Postby phatman3801 » Thu Jan 13, 2005 12:46 pm
can only get 96 gas here...so jst run stock settings then?
phatman3801
Postby Dr-X » Thu Jan 13, 2005 1:08 pm
Try advanced timing, if you're pinging too much, go back to stock.
Dr-X
Postby 10k 20v » Thu Jan 13, 2005 9:23 pm
i do doubt advancing the timing past the stock setting will net any gain, the ignition map will already be optimised from the factory to be run on 100 pump gas from japan and guess what, your only getting 96
10k 20v
Postby matt dunn » Thu Jan 13, 2005 11:35 pm
10k 20v wrote:i do doubt advancing the timing past the stock setting will net any gain, the ignition map will already be optimised from the factory to be run on 100 pump gas from japan and guess what, your only getting 96
I actually found on my blacktop that retarding the timimg by 2 or 3 degree's made it perform better.
I put it down to the fact that it's better to loose a couple of degree's of advance than let the knock sensors drop it back by 6 or so.
Matt
Postby 10k 20v » Fri Jan 14, 2005 8:10 pm
Matt
i agree totally
the knock system is bound to over correct for saftey
10k 20v
