phatman3801 wrote:i have a 1997 levin bzg with a blacktop..i have alwys knowen the low end power range isnt the best in the blacktops but a frind has jst got a bz touring with a black top and has a lot more low end power! much more than mine and is also standard! also i have let sumone i no who has had a lot of levins drive mine and he reckns a silvertop has better low rev power than mine..sooo im guessing sumthing is wrng with mine any thing u think it would b thats making my power not as good as wot it should be?? ne help would b gd! cheerz
EVLGTZ wrote:both running same timing? would make a world of difference if not that similar
10k 20v wrote:i do doubt advancing the timing past the stock setting will net any gain, the ignition map will already be optimised from the factory to be run on 100 pump gas from japan and guess what, your only getting 96
matt dunn wrote:10k 20v wrote:i do doubt advancing the timing past the stock setting will net any gain, the ignition map will already be optimised from the factory to be run on 100 pump gas from japan and guess what, your only getting 96
I actually found on my blacktop that retarding the timimg by 2 or 3 degree's made it perform better.
I put it down to the fact that it's better to loose a couple of degree's of advance than let the knock sensors drop it back by 6 or so.
Matt
