Broken Bolt advice please
Postby kazaral » Sun Feb 06, 2005 11:00 am
I noticed that there was a bit of oil coming out from under the bolt cover, grabbed my socket set went to nip it up and it came off as a put the socket onto it, how the hell do I replace it? And where do I locate another?
Only those willing to push themselves to far will know their true limits
kazaral
Postby fangsport » Sun Feb 06, 2005 11:25 am
by the look of it, you'll need to take off the rocker cover and remove the bolt, which, i think also holds the rocker gear in place. Toyota would supply one new if you can't get one from the wreckers.
fangsport
Postby Ae92typeX » Sun Feb 06, 2005 5:36 pm
& once you have taken the cover off it should come off pretty easy with some molegrips
Ae92typeX
Postby kazaral » Sun Feb 06, 2005 7:30 pm
Cheers guys, will have a crack at it this week :)
kazaral
