Panard Rod Bushes (Ae86)
Postby ~SlideWays~ » Thu Sep 11, 2003 2:11 pm
My brother replaced the bushes on either end of the panard rod (when he had an ae86) and he swears that it was a dramatic improvement.... only problem is that the Nolothane (sp) ones dont fit because the australian ae86 was different (was it an 85?)
So he had to order the TRD ones from japan and they are hell expensive, which brings me to my questions:
Are there any other options for quality replacement bushes?
Has anyone else replaced other suspension bushes in their ae86 and can recommend what to replace, short of doing them ALL!?
~SlideWays~
Postby Leon » Thu Sep 11, 2003 4:23 pm
Ring Mossrax... they can make pretty nearly everything for everything. Also, they are all Harbour Capital Car Club guys there, so they will look after you.
They made nolathane engine and gearbox mounts (three in total) for my Swift GTi from scratch... for less than the price of getting *one* made up from some crowd in Hamilton.
Postby suckymotor » Thu Sep 11, 2003 9:13 pm
have done the ones on my 86 just got them of the shelf from stocks but you will need to cut the factory one out if you need a hand let me know might be able to swap info on a couple of things
suckymotor
TS Original Member
Postby ~SlideWays~ » Fri Sep 12, 2003 1:47 pm
Leon: i'll have to look into that ay!
suckymotor: cheers man if i run into any probs i'll let you know
~SlideWays~
Postby Logan » Mon Jan 03, 2005 12:21 pm
Bringing up an old post.
I need to replace the rear bushes in the DX before next weekend. I have the panhard and sway bar sorted but having a few issues with the trailing arms.
Nolathane do not have a listting for the AE86 in their current catalogue, however an old catalogue lists 46060 as the part number, but is now an unknown part number in repcos system.
Have the options of superpros or noltecs as they do have listings, but cant get them cheap like i can the nolathanes.
So...Does anyone have anyidea of part numbers for nolathane trailing arm bushes? and availablity?
Logan
SR Sold. Onto Other Things
Logan
Postby AE85.6 » Tue Jan 11, 2005 7:00 pm
~SlideWays~,
ley us know what sort of difference it makes if ya can and what ones you went with, also is your panhard one the stock one or aftermarket ?
If you drink, and drift,
your a bloody lunatic
AE85.6
Postby 85AW20v » Tue Jan 11, 2005 8:37 pm
At Targa this year, in the strlet with AE86 rear end, we replaced the standard trailing arms and bushes for some solid mount rose jointed arms after the 3 stages on prologue day. The difference in feel was unbelievable. From feeling like the body was constantly trying to twist away from the tyres to absolutely no movement - just went where it was pointed. Grip was the same - just felt a whole lot better. The panhard rod is solid rosejoints as well - pivoting on a bracket mounted to the centre of the back of the diff, sort of a Z.
See ya
Simon
85 MR2 20v
85AW20v
Postby gdsup » Wed Jan 12, 2005 12:04 am
so those arms were rose joints on both ends of the arm? my panhard is a custom job rose jointed at both ends, feels alot better than the standard item
gdsup
Postby fangsport » Wed Jan 12, 2005 7:01 pm
one has actually descibed a Watts linkage. the daddy of live axle lateral control.
fangsport
Postby 85AW20v » Thu Jan 13, 2005 2:50 pm
Fangsport - yeah couldn't remember what it was called.
gdsup - yep the arms are solid rosejoints both ends.
See ya
Simon
85 MR2 20v
85AW20v
Postby spencer » Thu Jan 13, 2005 4:28 pm
so having a watts linkage means your roll centres dont get messed up when lowering the car? got any pics of how you set it up on your starlet
ms63 crown
spencer
Postby 85AW20v » Thu Jan 13, 2005 10:29 pm
ke70 - its my brothers car and he's in Morrinsville so you could have a look at it. It also has a link fom the top of the diff forward to above the driveshaft somewhere - can't remember how far - possibly in line with the front arms. PM sent with contact details.
See ya
Simon
85 MR2 20v
85AW20v
Postby fangsport » Thu Jan 13, 2005 10:41 pm
Simon85MR220v wrote:ke70 - its my brothers car and he's in Morrinsville so you could have a look at it. It also has a link fom the top of the diff forward to above the driveshaft somewhere - can't remember how far - possibly in line with the front arms. PM sent with contact details.
i was under the impression a bell crank was only necessary when the car dosn't have upper trailing arms, although i have seen one in a p/port powered KE70 circuit car
got any pics of the set-up?
fangsport
nolathane on AE86/85
Postby Xylotrope » Sun Feb 13, 2005 5:00 pm
I got my full car except the rear sway bar chassis mounts nolathaned at pedders ..
was a new car ...
rear is tight as now .. it steers properly too !
when you push the rear from the side it hardly moves ...
try that on standard .... anyone in the car will get seasick !
:P
Xylotrope
Postby fangsport » Sun Feb 13, 2005 7:25 pm
ask Chrispy about rear end movement, someone needs new bushes.
fangsport
