Replacing bearings in-car
Postby Pelo » Mon Mar 14, 2005 11:44 am
I want to replace the big end bearings in my MR2 engine rather than swap the whole engine over with my good one.
Is it possible to change the bearings while under the car in a pit without too much trouble? What will make my job easier?
It's a bluetop 4AGE
Pelo
Postby Ae92typeX » Mon Mar 14, 2005 12:42 pm
were you planning on getting the crank machined at all?
Im sure you could do it in car, but I have never seen anyone do it. I'd rather pull the engine- its not really a huge job to pull & is a good time to clean up the bay.
Ae92typeX
Postby ChaosAD » Mon Mar 14, 2005 12:50 pm
Ive done it before, but its best to pull out the engine and get the crank machined
ChaosAD
Postby edwagon » Mon Mar 14, 2005 6:50 pm
I have replaced bearings with the engine in-situ many times, including on a 3s powered sw20 mr2. In my experience, if you know by oil pressure or noises from outside the car (ie without engine in bits) that theres a bearing problem, its often too late for a set of shells to cure the problem, but having said that, it wouldn't hurt to pull the pants off in place to have a look, just as long as you're prepared to pull the engine and grind the crank if you have to. Its also alot harder and far messier to replace the bearings under the car, its often just as fast and a hell of a lot cleaner and more pleasant to just pull the engine and do it 'properly'. The hard way is often the easy way .
good luck! :)
edwagon
