4agze gearbox cooler possible?
Postby ATAl » Tue Apr 05, 2005 8:31 pm
There seem to be many internet rumours around that a oil cooler can be hooked up to a 4agze gearbox by removing the pipe loop at the bottom of the gearbox and hooking up cooler pipes instead.
Is this true, will it work by itself or would it require some sort of electric pump to move oil (also heard rumours that the box has a built in oil pump).
Has anyone ever done this?
ATAl
Postby 85AW20v » Tue Apr 05, 2005 9:08 pm
That loop pipe is connected to an internal oil pump in the gearbox so no need for any sort of external pump. Just remove the loop and fit your cooler.
See ya
Simon
85 MR2 20v
85AW20v
Postby matt dunn » Tue Apr 05, 2005 11:55 pm
Simon85MR220v wrote:That loop pipe is connected to an internal oil pump in the gearbox so no need for any sort of external pump. Just remove the loop and fit your cooler.
Yes the loop itself is like a mini cooler.
Postby ATAl » Wed Apr 06, 2005 3:34 am
So if I were to get a radiator out of an auto with the built in gearbox cooler, I could hook up the gze gearbox no problems (except making appropriate hosing of course)?
ATAl
Postby EVLGTZ » Wed Apr 06, 2005 8:15 am
yep
EVLGTZ
Ex 4AGZE AE82 - 14.2@163km/hr
EVLGTZ
Postby Fandango » Wed Apr 06, 2005 2:59 pm
sorry to hijack the thread. But, what difference does this make? Is it noticeable/ worth doing for a non race car?
or is there just less wear on the g/box?
Fandango
