tacho- negative of ignition coil or the ecu
Postby 2fas4u » Wed Apr 27, 2005 9:14 pm
hi all, last question in regards to hooking up a monster tach to a 90'sw20, which is easier to hook up the sensor wire too, the neg of igntion coil or the pin out on the ecu? where exactly to i find each of the too. not as mechenically minded n talented as some of u, if u could point me to where i can find each pref with pics or diagrams, will be greatly appreciated. hooked under the bonnet and engine bay but dunno what to look for. cheers. :D :roll:
2fas4u
Re: tacho- negative of ignition coil or the ecu
Postby matt dunn » Wed Apr 27, 2005 11:40 pm
2fas4u wrote: which is easier to hook up the sensor wire too, the neg of igntion coil or the pin out on the ecu?
Neither.
On a SW20 that already has a tacho it is easier to pull out the instrument cluster and hook into the existing tacho feed.
Matt
Postby 2fas4u » Thu Apr 28, 2005 12:45 am
Neither.
Matt
excellent! now which colour wire behind the instrument cluster do i hook up to on the existing rev meter?
2fas4u
Postby aesc » Thu Apr 28, 2005 9:43 am
If your going off the back of the dash cluster then it wont be a wire, but there are heaps of screws back there going into the back of the cluster itself. On mine I hooked onto the screw 'P' but it could be something different on an mr2, like N-
EX AE101 owner
2013 Ford Focus ST
aesc
Postby 2fas4u » Thu Apr 28, 2005 11:42 pm
aesc wrote:If your going off the back of the dash cluster then it wont be a wire, but there are heaps of screws back there going into the back of the cluster itself. On mine I hooked onto the screw 'P' but it could be something different on an mr2, like N-
wat do these letters short for? i spose p=pulse, n=negative?
2fas4u
Postby gdsup » Fri Apr 29, 2005 1:21 am
if it already has tacho in the dash that works why are you putting a monsta tacho?
gdsup
Postby TygerTung » Fri Apr 29, 2005 2:49 am
Must be broken I guess
TygerTung
Postby 2fas4u » Sat Apr 30, 2005 2:49 am
cos a gizmo shiftlite gonna cost me nearlly 200 bucks so for extra 25 bucks, i might as well get the tacho with it. :roll:
2fas4u
