m800, altezza 3sge with TRD manifold and vvti enabled
Postby Celica RA45 » Sun Jun 12, 2005 4:13 pm
just had my race motor dynoed it has 12to 1comp so can use 98 fuel 13mm cams also have forged rods as well as the pistons TRD inlet and extractors and i have vvti enabled as well so on a dyno dynamics dyno it makes 170 kws at 8700 rpm and in the torque in newtons it is over 3000 from 3500 rpm to 8000 rpm so a good torque line .The cams are moved 5 times in the inlet and only 2 in the exhaust from zero revs to 8800 red line and im using 7mgte injectors which are up to 75%duty cycle at the max so we are thinking at least 270 hp at the f/wheel and it still idles like a std motor thanks to the vvti ,so im happy it is the best result i have come up with ,with out vvti less torque and less kws 150 kws in locked in cams dialed in
Celica RA45
Postby RomanV » Sun Jun 12, 2005 4:19 pm
Aaah true, good stuff!
Whats that, 240ish hp at the wheels? 8O
Not bad!
You know I would really like to see some pics one of these days. 8)
Or a dyno plot would be nice too. :D
Postby beeker » Mon Jun 13, 2005 6:08 pm
Thought of supercharging it ?
94 DC2 Integra Race Car
02 M3 Race Car build
06 RS4 Avant
beeker
Postby CozmoNz » Mon Jun 13, 2005 7:32 pm
beeker wrote:Thought of supercharging it ?
with 12:1 compression ratio?
Rayne For President!
CozmoNz
altezza 3sge
Postby Celica RA45 » Mon Jun 13, 2005 8:30 pm
no im in the under 2 litre club cars ,most of the parts came from Bruce Sollitt your TRD agent ,the celica weighs in at 970 kilos before i get in it and im using a ta63 trd close ratio w57 box with Fseries TRD LSD and 4.6 diff ratio
also use the motec for logging and beacon as it draws a track at every circuit i run the car and has a speed sensor on the frt wheel to work out speeds and gears im in as well as the G force under brakes and in the turns
Celica RA45
Postby Adamal » Mon Jun 13, 2005 9:37 pm
Sounds taste. I'll bet shes pretty responsive :D
Re: altezza 3sge
Postby matt dunn » Tue Jun 14, 2005 7:40 pm
Celica RA45 wrote:also use the motec for logging and beacon as it draws a track at every circuit i run the car and has a speed sensor on the frt wheel to work out speeds and gears im in as well as the G force under brakes and in the turns
So do you run the motec dash aswell as the Motec engine ecu?
Matt
motec dash
Postby Celica RA45 » Tue Jun 14, 2005 7:58 pm
no dont need the dash as the price is way over my head
Celica RA45
Postby matt dunn » Tue Jun 14, 2005 8:30 pm
So what unit do you have for the G sensor, the basic lap timer? or it it an external device that you run as an input the the Engine ecu?
Reason I ask is just getting into the motec stuff at the moment and we have got the dash with the sensor internallly?
Just waiting for the car to be finished so we can fit it and power it up?
matt
Re: motec dash
Postby Adamal » Tue Jun 14, 2005 8:32 pm
Celica RA45 wrote:no dont need the dash as the price is way over my head
HAHAH! Sorry, I find that quite funny considering the cost of an M800 :D
motec m800
Postby Celica RA45 » Tue Jun 14, 2005 10:04 pm
im using a duel axis G sensor and also have a speed sensor on the frt wheel ,thats all i need plus the beacon and the transmiter
on my motec m800
have cam control enabled ,plus lamda ,upgrade memory 1mb ,and thats about it at the moment
the beacon sits on a camera tripod and the transmiter is mounted on the car
Celica RA45
Re: motec dash
Postby RomanV » Tue Jun 14, 2005 10:09 pm
Yeah, thats why he cant afford the dash! 8O
Either way, it sounds awesome.
AND I STILL WOULD LIKE TO SEE SOME PICS. :lol:
You can email them to me if you dont want to post any on the forum. :lol:
Motec ADL8
Postby beeker » Wed Jun 15, 2005 7:02 am
06 RS4 Avant
beeker
Re: Motec ADL8
Postby matt dunn » Wed Jun 15, 2005 8:51 pm
beeker wrote:http://www.trademe.co.nz/structure/auction_detail.asp?id=29347148
FYI
Yeah reseve price was $4000 ..... SECOND HAND!!!
Postby Adamal » Wed Jun 15, 2005 8:53 pm
Jesus Tityfucking Christ! Thats almost as much as an M800 NEW!
What the hell makes that dash so expensive????
