over drive pully 8psi?
Postby Voodoo » Thu Apr 21, 2005 6:13 pm
i recently added an over drive pully to my 4agze, anyway hooked up my boost guage and its only reading 8psi? yet it feels alot quicker than it did?
ive had a look through the tech sections on the abv mod, but because mines a transplanted engine the hoses are all over the place , and not like it looks factory,
so would it be possible that my guage isnt reading right or that for some reason ive still got the cut? would a 175m pully still make it quicker even hitting 8psi cut?
also has anyone got a pic of what the inlet bypass valve looks like and where the vacuum feed from the inlet manifold comes from
also thinking, what would happen it the bypass valve was disconected all together?
Voodoo
Postby evil_si » Thu Apr 21, 2005 7:39 pm
there is a small vacuum line to the bypass valve, (abv) disconnect and block this line,
you can go the the extent of removing the entire abv unit if you want, will need to plug the 2 ends off.
were have you taken the boost guage line from?
check the intercooler, hoses and clamps it could be possible there is a boost leak,
and pm me your address i still have a s/c dipstick sitting here for you.. :wink:
evil_si
Postby passenger pete » Mon Jun 27, 2005 7:21 pm
I have the same problem and putting boost to the abv does not do any thing.
did you ever get this problem fixed voodoo ?
passenger pete
Postby IH8TEC » Mon Jun 27, 2005 7:33 pm
you will get more boost sooner with a bigger pulley that size
Postby passenger pete » Mon Jun 27, 2005 7:53 pm
Its a 14 pound one that only makes 10pis
and by bypasing the abv it made 10psi
and blooking the vac line made it do 10psi
and bashing it with fing big stick made it goto 10psi
and yes its is a 14psi pulley kit
passenger pete
Postby IH8TEC » Mon Jun 27, 2005 8:12 pm
maybe you s/c is f*cked otherwise vaccum leak or abv,
Postby to4garret » Tue Jun 28, 2005 1:33 pm
could be your boost gauge too, my gauge was reading 11psi, but once on the dyno we found it was only making 8psi.
if its not a quailty boost gauge, dont trust it.
your problem is probably something else though :lol:
Horsepower is NOT proportional to the cross sectional area of your exhaust tip.
to4garret
Users browsing this forum: Google [Bot] and 20 guests
