Anyone CC'd a Silvertop head?
Postby 85AW20v » Thu Aug 04, 2005 11:36 pm
And if you have, did you also work out how much to take off for the domed pistons? I've used a TRD 0.8mm head gasket but the head already had 0.4mm off it as well so I'm wondering what the compression ratio is now. Its also an interference motor now so hopefully I don't break a cambelt :roll:
See ya
Simon
85 MR2 20v
85AW20v
Re: Anyone CC'd a Silvertop head?
Postby matt dunn » Thu Aug 04, 2005 11:54 pm
Simon85MR220v wrote:And if you have, did you also work out how much to take off for the domed pistons? I've used a TRD 0.8mm head gasket but the head already had 0.4mm off it as well so I'm wondering what the compression ratio is now. Its also an interference motor now so hopefully I don't break a cambelt :roll:
I did ages ago when I had my engine apart to work out my comp ratio,
but unfortunatly did not keep the info.
I had dished pistons so that end was easier to work out.
If you find out again let me know too please.
Matt
