Low_Aa63 wrote:Dude a hilux diff will handle any jandle!
Early celice diff will most likley be irs which is expensive to put into an ae86 as a new subframe will have to be constructed and there is also a good chance that you may get a t series irs diff and then youd be back to sqaure -1 as the sub frame would still be required!
and theres an even smaller chance of getting the ma45 celica diff which is just an old school version of the 86 diff being live rear axle!!
even then youve got to worry about ratio's!!
Best bet is hilux rear (possibly off some description of smaller van which will maitain 4 stud hub) with brakes from an old school toyota (disk ofcourse) with external hand brake, and most of the time they will be either 4.1 or 4.3 ratio 4.3 being the better for power applications but 4.1 being a nice overall diff!
Any questions??
Drifter4ag wrote:i wouldnt call it over kill by any means for an na engine . You can beat them all day with no worries at all .. .
Low_Aa63 wrote:the only thing similar between f series irs and independant is the crown and pinion wheel size! the spider casing/lsd clutches/whatever you put in there is not the same and will not fit! Irs being the bigger one ofcourse!
