Car Horn
Car Horn
Postby femaleshopper » Sun Oct 16, 2005 10:10 pm
My horn doesnt work any more, it worked if you pressed in a certain area, but now wont work at all, would it be connections or do they "die" after a while.
Help would be great on this
Regards
femaleshopper
Postby AJz » Sun Oct 16, 2005 10:48 pm
is the horn on a stock steering wheel or aftermarket?
what sorta of car is it in?
sounds like the contact points have slipped where the horn part of the steering wheel is supposed to hit and therefore set the horn off. Take the horn apart if you want to fix it yourself, usually held on by either grommet things, or screws.
I had vtax :(
AJz
Postby femaleshopper » Mon Oct 17, 2005 5:37 pm
Its teh standard wheel, its in my 88 GTI, yeah I need to sort it as my WOF is due soon, and its a pain not giving bad drivers a go on the horn.
Thanks for your input so far
femaleshopper
