4AGE or worked 4K?
4AGE or worked 4K?
Postby streatracer » Sun Nov 06, 2005 5:08 pm
i have a kp60 with 4k and 5spd should i put a 4age in it or work the 4k? I dont mind spending the money on a 4age but as i am not really interested in huge power is it worth it? i am told a 4k with side drafts cam and head work can go pretty good but would a 4age go even better in (almost) standard trim? I am looking for 70-80rwkw
go hard or go home
streatracer
Postby vhpacer » Sun Nov 06, 2005 5:12 pm
A 4age would use a fraction of the fuel that a worked 4k with sidedraughts would for a start.
vhpacer
Postby Jebus » Sun Nov 06, 2005 5:25 pm
A good condition stock 4age will go alot better than most worked K's, unless its a mega $$$ build.
If you have a stock 4age, say 130hp fly, and a 5K with 130hp fly.
The 4age has power for alot longer through the rev range
Is smoother
will use 1/43272th the gas
will look cooler
and probaly end up costing less
and be more reliable
The 5k will look more oldschool
and possbily sound tougher
but you wont need to $&#$% around with other shit like wiring, new g/box, certs, fuelling.
For example my old 5K made the same figures on the same dyno as a 4AGE starlet, but my KE30 on the road was no where near as fast as that was.
Jebus
Postby streatracer » Sun Nov 06, 2005 5:37 pm
what about an sr20de? i know the purists will crucify me but i think it wud go hard in a 7-800kg starly anyone done it? (road legally)
go hard or go home
streatracer
Postby Jebus » Sun Nov 06, 2005 5:59 pm
SR20DETS have been done platy of times into old toyotas, a bit more work than a normal 4AGE swap, and why bother when you only want 70-80rwkw.
Jebus
Postby Lloyd » Sun Nov 06, 2005 6:13 pm
Stay old school with the 5K. Or if you've got time to waste you could go 7K hunting... then turbo it and so on and so on...
Postby r/t_ranger » Sun Nov 06, 2005 6:35 pm
Or a 3t. easy to fit and they go fairly hard with a bit of work. Super cheap to buy to.
r/t_ranger
Postby pc » Mon Nov 07, 2005 8:34 am
I've heard the old suziki 1300 (double overhead cam) goes well in a starlet. The engines come in barinas I think.
Should be economical and light.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby wde_bdy » Mon Nov 07, 2005 8:42 am
pc wrote:I've heard the old suziki 1300 (double overhead cam) goes well in a starlet. The engines come in barinas I think.
Not cheap though by the time you adapt a gearbox.
Callum
wde_bdy
Postby pervert » Mon Nov 07, 2005 8:45 am
Jebus wrote:The 5k will look more oldschool
Not possibly, it WILL sound tougher... :lol:
Use a 5K, K series are the best engines ever made... 8)
pervert
Postby Mr Revhead » Mon Nov 07, 2005 9:34 am
whats the problem?
4age = win
more power, cheaper, more reliability, more economy.
k series = old slow boat anchor
Postby wde_bdy » Mon Nov 07, 2005 9:55 am
Mr Revhead wrote: k series = old slow boat anchor
You might want to check a few race tracks before you say that. There are a few putting down some pretty respectable times on not very large budgets.
Callum
wde_bdy
Postby Mr Revhead » Mon Nov 07, 2005 9:59 am
that is true.
but how much of that is due to the engine and not suspension etc?
and in relation to a 4age?
and i was being a bit of a smart arse there :P
but imo a 4age is a better choice for a road car.
plus to get about 100hp at the wheels liek hes after, its going to be a fairly warm k engine....
Postby Blown5k » Mon Nov 07, 2005 5:48 pm
Well i have beaten everything up to 2000cc at Canterbury Car club race days so far with my 3k including a sr20de pulsar and a 2lt vtec race car ...even a evo when combined with the 50% of the fastest cars field :lol: still life in the K yet!
Supercharged 5k kp60
2005-2006 1301-1600cc Canterbury Car Club race series champion.3rd 0-2500cc.
Blown5k
Postby bad20v » Mon Nov 07, 2005 5:52 pm
Or you could go really trick and build a 2AGE!!! Done properly they are good for around 120-130 Hp and rev like hell!! :D
Thank-You.
bad20v
Postby Big pun » Mon Nov 07, 2005 5:55 pm
work out how much $$$ the 4age conversion is gonna cost you then spend it on your 4K
4age *yawn* what a mission..
Big pun
Postby Adamal » Mon Nov 07, 2005 5:57 pm
I'd go with the 4AGE.
Another reason to add to the already mentioned things is the availability of
A) Parts from wreckers
and
3) Super Happy Fast aftermarket parts from Nihongo V(^_^)
