Levin GTZ 1991+ max boost on stock charger
Postby UZZ30 » Sun Nov 20, 2005 2:17 am
Whats the maximum boost you would want to make using the stock supercharger on a 4agze that would be reliable?
UZZ30
Postby IH8TEC » Sun Nov 20, 2005 10:16 am
covered many times, but 14psi, otherwise they hit fuel cut,
Re: Levin GTZ 1991+ max boost on stock charger
Postby Crucible » Sun Nov 20, 2005 10:46 am
UZZ30 wrote:Whats the maximum boost you would want to make using the stock supercharger on a 4agze that would be reliable?
S/C Rotor Teflon melts above 15 - 16 psi, AE101 E.C.Us are only mapped for 14psi so wouldnt go above this anyways.
AFM AE92 can be run slightly higher boost I think, not certain on mapped AE92 thou??? do a search :lol:
I get 13 - 14psi with an Evil-Si 175mm Pulley kit on my AE101 (Smaller S/C pulley) :lol:
TNT
Crucible
Real Life Mechanic
Postby FLAWLES » Sun Nov 20, 2005 11:04 am
yep 14-15psi
im running 15 -16 psi on my 101
but i think u will find that the tefflon coating ill melt at alot higher psi then that ie like 20psi +
the bearing on the sc will goe first
FLAWLES
Postby UZZ30 » Mon Nov 21, 2005 12:00 pm
how many psi does the stock pulley make?
UZZ30
Postby Crucible » Mon Nov 21, 2005 12:11 pm
UZZ30 wrote:how many psi does the stock pulley make?
I was getting 9 psi with abv Mod, 10 psi max on a cold night, with factory Pulley (145mm).
I fitted one of Simons 165mm pulleys to a friends 101 and he was getting 12 - 13 psi, I think EvilSi said anywhere up to 16 psi with a 175mm kit depending on S/C condition.
Mind you 14psi with a Heat soaked Top mount cooler is very noticable - ie - big powerloss Ive noticed :cry:
TNT
Crucible
Real Life Mechanic
Postby Crucible » Mon Nov 21, 2005 12:40 pm
CozmoNz wrote:then fit a smaller s/c pully, avilable through fensport.. and run 20psi :D
and destroy the supercharger in a matter of days...
be very amusing through ^_^
I think if you are going to drive the charger above 15psi youd be better jumping on the turbo bandwagon :lol:
It starts developing more heat than useable pressure from what I understand.
My blower screams its nuts off in the higher RPM range with the Big pulley, Overdriving it even further would make yah cringe :?
TNT
Crucible
Real Life Mechanic
Postby evil_si » Mon Nov 21, 2005 5:34 pm
as said 14psi is reliable. stock everything is fine
17psi goes a lot better but with out a decent intercooler is a waste, and traction is a pain in the ass.
on map sensed engines it will hit boost cut.
21 psi and you will destroy a blower on average every 3 days. :roll:
evil_si
