Zenki axels shortening required?
Postby SKDTOY » Tue Nov 22, 2005 11:04 pm
Hi .I have a problem with my Zenki LSD conversion . Ive just fitted a Zenki LSD into my TE71 housing and is all good .But when I slipped the axels in they were 3.5mm to long as in the outter bearings were not fully home . So my question is,is this normal and do they require shortening ? I'll turn 4mm off them and see what happens . What do you think has anyone had this same problem?
SKDTOY
Postby Rick » Tue Nov 22, 2005 11:14 pm
yes they will need to be shortened cant remember the amount, try a seach it has been covered before.
Axels Zenki LSD
Postby SKDTOY » Tue Nov 22, 2005 11:37 pm
Cheers man I'll Give it a try .Anyone else got the info on hand?
SKDTOY
Postby suberimakuri » Wed Nov 23, 2005 9:41 am
maybe go 5mm...
suberimakuri
Axels up date
Postby SKDTOY » Fri Nov 25, 2005 8:08 pm
Got it sorted sweet. Now this is how much i took off . I just ground more off till they fitted up sweet . REQUIRED REMOVAL OF (9MM) TOTAL . If i was to do it again i would get them lathed down but since i didnt know exactly how much to remove initialy .I did it gradualy with a grinder I know it sounds ruff but it good enough. TOTAL REQUIRED REMOVAL (9mm) FROM THE SPLINE. \ THE AXLE SHOULD MEASURE (560mm) FROM THE INNER SIDE OF THE STEEL OIL SEAL RETAINER/FITTING WHEEL BEARING END TO THE TIP OF THE SPLINE AFTER MACHINING.
SKDTOY
Users browsing this forum: Bing [Bot], Google [Bot] and 9 guests
