idle not staying still and backfiring (4k)
Postby scope » Fri Jan 20, 2006 4:10 pm
Mmm, Boost wrote:You havent fixed this yet? 8O Gasket is like $10 from Repco, and it'll take all of half an hour to do :P
aha so i did it today. it fixed the idle problem but still backfires when slowing down ?
chicken fillet and bacon with everything except onion and bbq, ranch and southwest sauces
current ride: 1980 mazda rx7 series 1
previous rides: ke36 corolla, series 1 rx7, ke30 corolla, ke70 corolla x2
scope
Postby Dell'Orto » Fri Jan 20, 2006 6:21 pm
Bit of fuel going out the exhaust, nothing major ;)
backfiring
Postby gothegravel » Fri Jan 20, 2006 6:35 pm
Not sure how your 4k is modified but with a 4k you can run a 3kb head with a 3kb inlet manifold and twin carbies. It works bloody well especially if you match port the inlets.
gothegravel
Postby vhpacer » Fri Jan 20, 2006 8:19 pm
Is the engine stock standard just with the exhaust?
Try turning the mixture screw anti-clockwise half a turn.
Have you tried this?
vhpacer
Postby scope » Fri Jan 20, 2006 8:55 pm
yep
scope
