wats with the ae82 fxgts and the wheel studs
Postby escortman » Wed Jan 25, 2006 10:39 pm
i have tried a couple of different magz on my ae82 fxgt, but when it comes to putting the nuts on the studs dont seem to be long enough, has nebody else had this problem i showed a tyre show in glen eden and they said theyv seen worse, lik they appaer to be only lik 3-4 mm to short, i priced up getting longer studs and it was gona cost bout 40 buks a hub and these studs would be bout 30mm longer so would need to be cut, these prices were at cost as well, i also dont want to do this because to get the fronts out i run the risk of breaking the bearing, wat can i do :?:
escortman
Postby THA SHZ » Thu Jan 26, 2006 6:51 am
cum into my shop and il have a look at it . give me a call on 276 8740 or drop into Frank allen tyres in otahuhu and ask for pete and il sort it out for u 8) cause from wot uve written i cant quite understnd wot u mean but i wood say most likely ur trying to run the wrong offset wheels 8)
THA SHZ
Postby no_8wire » Thu Jan 26, 2006 7:31 am
Its interesting, as the offset that fitted on my car (the MR2) runs the same FWD offset as his is supposed to...yet they fitted on mine fine...
His studs are quite short...
no_8wire
Postby pc » Thu Jan 26, 2006 11:21 am
I have the same problem with mine... the warrant guy didn't like it so I put wheel nuts on that are covered over the top... so you can't see that the nut isn't on very far.
red car
1/4 mile - 14.683s @ 91.83mph
Manfield - 1:24s
pc
Postby escortman » Thu Jan 26, 2006 2:41 pm
THA SHZ wrote:cum into my shop and il have a look at it . give me a call on 276 8740 or drop into Frank allen tyres in otahuhu and ask for pete and il sort it out for u 8) cause from wot uve written i cant quite understnd wot u mean but i wood say most likely ur trying to run the wrong offset wheels 8)
ill drop in sometime 2moro and show u wat i mean where in otahuhu are you
escortman
Postby sergei » Thu Jan 26, 2006 2:48 pm
are you using the right wheel nuts?
Some are conical and some (especally on stock toyota mags) have washers and go right through the mag.
Postby escortman » Thu Jan 26, 2006 3:57 pm
its got teh stock steelies at the mo but i got some 14s off another car i bought that still use the conicle nut, i was thinking of removin the steel piece that the magz had and using shank nuts but they wud stick out 2 far
escortman
Postby THA SHZ » Thu Jan 26, 2006 9:35 pm
escortman wrote:ill drop in sometime 2moro and show u wat i mean where in otahuhu are you
25 salesyard rd , otahuhu .
its the truck bypass rd tht runs between great south rd and massey rd 8)
THA SHZ
Users browsing this forum: Bing [Bot] and 27 guests
