Any alloy fabricators?
Postby sergei » Fri Jan 27, 2006 8:13 am
Hi, I have ST165, for which I need a special bit fabricated out of alloy:
it is the bit which goes between throttle and original intercooler.
I can provide original item to copy.
In fact I can courier it to you if you are not in Auckland with an extra bag, and do a bank deposit for payment.
Anyone can help me here?
here is the stolen pic:
the thing I'm after is in the top right corner
Postby Dell'Orto » Fri Jan 27, 2006 9:39 am
Whats wrong with yours? Just go pilfer one off a wrecked SW20, it looks identical to what you've pictured there.
Postby sergei » Fri Jan 27, 2006 9:48 am
Mine one is made of rubber so when I put silicone hose on it and tighten it up it squeezes a fair bit (I have ST205 intrecooler so I can't stretch it on it)... Unless some one has metal one who wants to sell it to me.
Postby Malcolm » Fri Jan 27, 2006 11:30 am
you could probably make one very easily of steel. The MR2 one will be too long and hit the intercooler I suspect.
Postby sergei » Fri Jan 27, 2006 11:45 am
there is nothing a hacksaw can't fix ;), as long as MR2 one is the same base and made out metal, I would go for it...
I don't like steel because it will rust (mild steel) and looks horrible...
Postby Andy7447 » Fri Jan 27, 2006 12:11 pm
i kan do you one out of mild steel and get it painted (or chromed)
1989 Celica GT-FOUR
Andy7447
Postby THA SHZ » Fri Jan 27, 2006 11:11 pm
pm evil si , he can alloy weld 8)
THA SHZ
