HELP!!!! Can anyone help drill out exhaust manifold stud.
Postby Wildcard » Fri Feb 17, 2006 9:59 am
Mr Revhead wrote:the mr2s dont appear to have the same issue.
but yes there is a hole there already. no idea why it isnt used, i think some jap guy missed a line on a drawing or something
My Blitz turbo is based on the Caldina one though so unfortunetly I get the manifold-of-ridiculousness like the rest of the ST215 owners. The manifold is the facelift one with the extra stud hole luckily so I'll grab a stud for that.
Does anyone have the torque setting for these the stud nuts?
Wildcard
Toyspeed Founder
Postby Rob » Fri Feb 17, 2006 5:15 pm
All you need to do is drill slightly larger than the stud until you hit .(this stops the bur on the broken stud from catching and rapping your threads)
Once you've done this you can centre punch the stud and drill it out to about 5mm. Then you can use an ezyout. A guy who does all our skypig engines showed me this why and it works every time so far :wink:
1990 ST185H - project
1996 VS Acclaim wagon
Rob
Postby Akane » Sat Feb 18, 2006 1:29 am
99gtt, you still havin't replied to my post, how do I make more power out of my setup. I'm losing sleep everynight, thinking there is more power to be untapped, but nobody knows how except you.
Postby 99gtt » Sat Feb 18, 2006 10:35 am
Akane wrote:99gtt, you still havin't replied to my post, how do I make more power out of my setup. I'm losing sleep everynight, thinking there is more power to be untapped, but nobody knows how except you.
Ahhhh TUNE IT
SOON TO BE 500 HP
99gtt
Postby 99gtt » Sat Feb 18, 2006 10:39 am
Drilled the stud out successfully , got a new gasket set . And the manifold doesn't seem to be warped as there is no leaks. So problem fixed for less than 30 bucks.
SOON TO BE 500 HP
99gtt
Postby Mr Revhead » Sat Feb 18, 2006 12:58 pm
hmmm sorry, only temporary. it will resurface, probably within 2 months.
Postby 99gtt » Sat Feb 18, 2006 10:27 pm
Thats all it needs to last for as i am currently making up a custom manifold myself . By then i should have new turbo to match and finish my home made water to air intercooler .
SOON TO BE 500 HP
99gtt
Postby Mr Revhead » Sun Feb 19, 2006 11:16 am
sweet as. sounds like a good alternative 8)
