by Chickenman » Sat Apr 01, 2006 10:43 pm
I think a supercharged/turbo fe is a good Idea, better cams for low rev torque and relatively low compression.
Of course, they will explode on a regular basis but at around $300 or less for a complete replacement engine it could be a good bit of fun. Setup costs could be as little as $400 (second hand turbo and manifold, little bit of fab to get an oil drain/feed etc) and then it would be a minor issue to swap the gear over when you 'splode things.
This is assuming you can change engines/do most of the work yourself.
If not, buy a 3sgte. Turboing a 3sge is a bitch by all accounts so probably not the best suggestion either.
Baby Jesus
