Done a manaul conversion a while ago and was under the car makeing sure nothing was going a berkers on me. Was having a close look at the push rod (as i turned it myself) and noticed that it was pressed HARD up on the clutch fork looking like it may actually be slightly pushing it partially disengaging the clutch.
I'm Fairly sure i cut it so it was right but in looking at it, it is definatly a tight fit eg. no movement. The question is, Would the cylinders move untill the push rod was just in contact or what? because if my clutch isn't engageing propper it'll probably be worn out real soon :/
