Clutch slave cly.->push rod->clutch fork interaction.
Postby Quint » Tue Apr 11, 2006 11:48 pm
Done a manaul conversion a while ago and was under the car makeing sure nothing was going a berkers on me. Was having a close look at the push rod (as i turned it myself) and noticed that it was pressed HARD up on the clutch fork looking like it may actually be slightly pushing it partially disengaging the clutch.
I'm Fairly sure i cut it so it was right but in looking at it, it is definatly a tight fit eg. no movement. The question is, Would the cylinders move untill the push rod was just in contact or what? because if my clutch isn't engageing propper it'll probably be worn out real soon :/
Quint
Postby Ae92typeX » Wed Apr 12, 2006 12:18 am
if you machined it to long than it could be doing this, otherwise, yes with a hydro clutch, the slave push rod will always be in contact with the clutch arm.many cars have a sping between the two ensureing they are always in contact.
did you try moving the clutch arm at all. usually you can get afew mm of movement by pushing it before contact of the release bearing to pressure plate
Ae92typeX
Postby kingcorolla » Wed Apr 12, 2006 12:40 am
In a hydraulic setup pushrod length will not provoke any movement in the clutch until the slave cylinder is 'bottomed out' in the bore. If you still have backwards movement in the cylinder then it shouldnt be causing a problem.
If the pushrod is acting on the fork then it would of been a struggle to install the cylinder.
1983 Carina AA63 4age
kingcorolla
Postby edwagon » Wed Apr 12, 2006 8:20 am
the above is all correct, but also bear in mind that as the clutch wears, the arm will move back towards the slave, so that if your pushrod fitted ok to start with, as the clutch wears it will get closer and closer to bottoming out.
Just make sure you can still move the arm back off the pressure plate a bit before the slave bottoms out and its fine
edwagon
Postby Quint » Wed Apr 12, 2006 3:01 pm
Cheers,All. Hadn't given that much thought Ed, Will have to keep that in mind and keep monitoring it.
Worn out exedy clutch = unhappy boy ;)
Quint
Postby kingcorolla » Wed Apr 12, 2006 11:31 pm
edwagon wrote:the above is all correct, but also bear in mind that as the clutch wears, the arm will move back towards the slave, so that if your pushrod fitted ok to start with, as the clutch wears it will get closer and closer to bottoming out.
hmm ok this is also correct but
clutch wear will only counteract on the slave in a pull type configuration which the majority of toyotas dont have
also a clutch has to wear for thousands and thousands of kms for less than a cm of adjustment
If your worried about it, check it.
kingcorolla
Postby edwagon » Wed Apr 12, 2006 11:41 pm
ummm, not too sure what you mean by counteract, but when the clutch plate gets thinner (wears), the pressure plate moves closer to the flywheel, so the fingers of the diaphram will move away from the flywheel, reducing freeplay....
edwagon
