cross drilling and slotting???
Postby vr4boy » Wed Apr 19, 2006 9:41 pm
where can i get this done? or buy them already done for an sw20?
1995 ae101 levin st 20v
vr4boy
Postby Jebus » Wed Apr 19, 2006 9:54 pm
0800 Brakes, give them a call.
I havnt enquired but id say they wont drill/slot old second hand rotors that arent thier own. You can buy off the shelf drilled/slotted rotors as bolt in replacments, your usual stockists sell them, but 0800 Brakes are best.
Jebus
Postby Lloyd » Wed Apr 19, 2006 10:29 pm
http://www.dba.com.au/DBASTDseries_cat.pdf
Only one listing for SW20s, I dont know if they just use a single size rotor on most models or not. Show a listing for slotted and crossdrilled though
Dont do it to standard items. Crossdrilling will only make them weaker
Postby Dell'Orto » Thu Apr 20, 2006 12:42 am
The Masterton Repco have a pair in stock, thats for Gen 1 SW20. I bought the last set of plain slotted rotors for my car, they're bloody good.
Postby Akane » Thu Apr 20, 2006 5:37 pm
http://lol.co.nz/5zigen/DSC04451.JPG
But seeing your SW20 is NA, dunno if they make the smaller brakes with Slotted........
Hold on, you have an NA, why would you need slotted rotors?
Postby slighty_looney » Thu Apr 20, 2006 6:53 pm
you could jst buy stanard new disks and get them drilld, iv seen it done on this old'r doods evo at my dads work , looks the part and hes neva had any problems with it
FC3S
Robinson Steel Fabrications
Current Ride: 88 rx7
Project: viewtopic.php?t=88412
Discussion: viewtopic.php?t=88413
slighty_looney
Postby vr4boy » Thu Apr 20, 2006 9:15 pm
AKANE my car is in the process of a full rebuild, which will include a turbo convertion, going to do it all once and do it right, so the brakes are getting upgraded.
lookimg at getting some bigger rotors i have drilled and or slotted is all.
vr4boy
Postby Akane » Fri Apr 21, 2006 2:28 am
What year is your MR2? does it have the 92 bigger brakes?
If you're still on the older 91 brakes, you might want to do a brake conversion first to the later bigger brakes.
If you're on 92+, you'll find a pad upgrade is already good, but if you're motherfriggin' EXTREME >_<!, you might want a BBK (Big brake kit).
Now, are you EXTREME >_<! ?
Postby vr4boy » Fri Apr 21, 2006 8:41 pm
mine has the older smaller brakes at the moment but am up grading to the later model brakes, and want to slot and drill the rotors as i intend on getting some track time once its finished.
vr4boy
Postby Lanius » Fri Apr 21, 2006 9:33 pm
General consensus is that its dangerous to cross-drill standard disks, as you stand a higher chance of fractures or cracks in the disk, leading to *very* unpleasant results at high speeds. Cross-drilling is a bit over the top for a road car. Slotted rotors should be the most you need (like in Akane's pic) unless you're planning on doing some very hard track driving. Much safer to buy disks pre-moulded with the slots in them.
Again, 0800 Brakes are the way to go.
Lanius
Postby Akane » Sat Apr 22, 2006 3:13 am
I got my brake discs from 0800 brakes, make sure you get the DBA ones, not the China made ones I got.
I thought mine were brembos until I go pick them up.
Postby RomanV » Sat Apr 22, 2006 3:54 am
Akane wrote:But seeing your SW20 is NA, dunno if they make the smaller brakes with Slotted........
Too much american forums for you!
Bad AKane, Bad!
J spec :roll: brakes are the same, whether turbo or Na, only difference is gen 2+ or not.
Postby Akane » Sat Apr 22, 2006 8:55 am
Hey, god bless America!
Postby magweal » Sat Apr 22, 2006 11:23 pm
I got slotted my 1's in my BZ-T rolla from Zonllei in Manukau, working great
magweal
Postby snwtoy » Sun Apr 23, 2006 11:03 am
Surely slotted rotors are a waste of time on a road car, not to mention they munch through pads a lot quicker. You'd be better off spending money upgrading the callipers.
snwtoy
