20v problem help
20v problem help
Postby ae82gt » Mon Apr 24, 2006 12:34 pm
coming home last night my sliver top had a dead spot about 2500rpm it became worst and now will only idle , rebooted the computor this morning ran sweet for about 2mins then it will only idle again. have no idea where to start looking for the problem , any help would be much appreciated. thanks mat
fxgt ae82 20v
fxgt ae101
ae82gt
Postby Punter » Mon Apr 24, 2006 12:46 pm
Did you check for error codes before you reset the ecu?
Punter
Postby AceSniper » Mon Apr 24, 2006 5:56 pm
sounds alot like sumthen iv come across
open up the ecu look over the capacitors there are two that are common to fail in the ae101 ecu... causing issues!!
just sumthen to check
AceSniper
Postby Mr Revhead » Mon Apr 24, 2006 5:58 pm
do that after checking the codes....
codes may point to it, if no codes then check above as that fault doesnt show codes
Postby dazzag » Mon Apr 24, 2006 6:45 pm
i have come across two silvertops before with the same syptom. i put a timing light on it and the igntion would not advance when reving. no fault codes although engine light would come on while driving. both times the ecu was faulty. removed and sent to a place in nelson called anything electronic.
want a ae86, dont want to pay 8 grand for one
have to settle for my ae92
dazzag
Postby ae82gt » Mon Apr 24, 2006 7:36 pm
thanks, no error codes , got an spare auto ecu if i plug that in is that going to cause any issues?
fxgt ae82 20v
fxgt ae101
ae82gt
Postby dazzag » Mon Apr 24, 2006 8:58 pm
is your car manual? try plugging it in and going for a drive. it may come up with a fault code if your car is manual but just give it a go and see
dazzag
Postby slighty_sykotic » Mon Apr 24, 2006 9:14 pm
It won't fit, plugs are different AFAIK.
You would have to rewire for that.
--Sykotic
slighty_sykotic
