Water to Air faults
Water to Air faults
Postby Adydas » Fri Apr 28, 2006 3:26 pm
Right, trying to help someone so see if you can un stump this..
Pulled codes, got a fresh 54 code, Intercooler on a ST185 RC.
Pump checked to be working, water level was low but has been filled to confirm thats ok. Reset ecu and drove 600m later FAULT light..
Whats the next best thing to check?
Adydas
Postby sergei » Fri Apr 28, 2006 4:31 pm
is the water level sensor connected?
Have you played with wiring at all?
Postby GT4 20 » Fri Apr 28, 2006 4:50 pm
Have you re-checked the water level?
Gary
1999 Subaru Legacy B4 RSK TT
GT4 20
Postby Adydas » Sat Apr 29, 2006 12:44 am
Yeah, its fine and full codes reset..
Adydas
Postby Akane » Sat Apr 29, 2006 4:59 am
w2a ftl :(
Postby GT4 20 » Sat Apr 29, 2006 8:28 am
Akane wrote:w2a ftl :(
Yet another classic helpful post :roll:
Adydas
I wonder if the level sensor is causing the problem. Why not remove it and check it's functioning okay? Not sure if it's a n/o or n/c contact switch though. :?
Gary
GT4 20
Postby Loudtoy » Sat Apr 29, 2006 8:46 am
Adydas
Gary
Ah intermitent faults the, worst kind, are you the water level sensor would simply be no or nc contact?? Most sensors live that are variable resistor type things that then have a controller around somewhere after it to convert the signal or porbably in the computer.
Sounds to me like you have a plug almost but not quite in somewhere or a dry solder joint, check all posible plugs and connections 1st, Probably won't even be very loose just enough to wriggle about a little
TS Member sine 2001
Prado To tow stuff with
Rodeo to do work stuff in
Loudtoy
