opticalblue wrote:have you check the plugs to see if the wires may have come loose... do the wiggle test...
CircuitLevin wrote:Pretty sure its not the sending...
matt dunn wrote:CircuitLevin wrote:Pretty sure its not the sending...
because...........
CircuitLevin wrote:Pretty sure its not the sending because we replaced it with another.
matt dunn wrote:CircuitLevin wrote:Pretty sure its not the sending because we replaced it with another.
Usually a good way to tell.
Have you hooked up anything that may be killing the signal such as speed meter, speed cut defender, etc etc?
otherwise you may be looking at a dash problem.
